M*****
Another Excellent PCB
I have received the latest PCB in the post within the time quoted and on inspection I have received another very high quality PCB for the following reasons: 1. Silkscreen sharp and clear and has good adhesion. 2. Solder resist has sharp well defined edges around components pads. 3. Solder adheres readily to solder pads. 4. Plated holes (1mm holes are viewable inside) have shiney uniform plating inside with no non-plated areas. Another great job!
  • Comments( 1 )
  • Thank you for your detailed feedback and sharing your experience! We will continue to work hard to provide you with the best services :) ————————Elecrow Team
    Nov 04,2025 0 comments
    Reply
