micha nisani
  • 1 Projects
  • 0 Followers
  • Nov 28,2025
Makera Carvera Clamp-UnClamp device
when using the 3D probe like WP500 , the user need to send Clamp-UnClamp command to the CNC macine in order to catch the probe. But if the controll PC is far from the machine it is difficult to hold the probe and insert it manualy to the router, and send the command to clamp the probe. I use small device M5Stack core, that attach to the machine , and it connect to the CNC by the wifi network and carvera tcp protocol for MDI commands. by using the 3 M5stack buttons i can send commands directly to the CNC.
1. Use ardiuno IDE with M5Stack unified library
M5Stack core is ESP32 device.
2. The software build on startup internal ARP table, by using ping command, from this ARP table the software  find the MAC address of the CNC, and from the MAC's ARP table , it get the IP address of the CNC, and used it for wifi connection.
3. The M5Stack unit need to be in the same wifi network as makera carvera.
4. I use the Carvera_Community_Firmware in my CNC in order to use 3D probe
https://github.com/Carvera-Community/Carvera_Community_Firmware
5. The probe WP500 has only two wires: red and black. The red is the GND !!!!, black is NOpen signal
6. The connection of the 3D probe is done by using the 2-pin connector on the left side table in the carvera CNC.
JST-2mm
7. The GND and Signal NOpen from the probe , come to the 2-pin connector  that locate inside the machine table, from the table left side.
8. We Can change the software to support any G or M commands to carvera
9. The M5 stack has 3 buttons:
A- (left) use to Clamp the probe . or wake up the device after shutdown.
B- (Middle) use to Unclmp the device
C- (right) use to move the CNC routet to the left 100 mm in order to insert the 3D probe.
Long press ( 3 sec) on C button use to shout down the unit and close the wifi connection.
10. If you want that the 5V power to M5Stack unit, will come from the usb port on the Carvera LEFT side:
You need to switch the internal USB connection cable, in the Carvera back pannel,  from right side to left side
Or - External 5V power USB-C supply can be used.
11. 3D plastic model (PLA) design in fusion-360
  • INO file and fusion 360 file
    project_15608238169296738ab588.zip
    Download(0)
  • box
    carvera_left_usb_v11_1436544575692966d9caaa2.stl
    Download(5)
1.1k
16
  • Like( 16 )
