Malik Bruder
  • 3 Projects
  • 4 Followers
  • Apr 27,2025
Getting Started with the Pico W5
I was having trouble finding a guide to get started with the Pico W5, so here is what I did. Hopefully it works for you too!!
🔧 How to Use Elecrow Pico W5 With Arduino IDE (Blink LED)
🧰 What You Need:
  • Elecrow Pico W5 (RP2040 version)
  • USB-C cable
  • Computer with Arduino IDE installed (get it from arduino.cc)
✅ Step 1: Connect the Pico W5
Plug the Pico W5 into your computer using a USB-C cable.
⚙️ Step 2: Add RP2040 Support to Arduino IDE
  1. Open Arduino IDE
  2. Go to: File > Preferences
  3. Find the “Additional Board URLs” field
  4. Paste this URL in:
    https://github.com/earlephilhower/arduino-pico/releases/download/global/package_rp2040_index.json
  5. Click OK
🔌 Step 3: Install the Board Package
  1. Go to: Tools > Board > Boards Manager
  2. Search for: “Raspberry Pi Pico/RP2040”
  3. Click Install (by Earle Philhower)
🧭 Step 4: Select the Board
  2. Select “Raspberry Pi Pico” (even though it’s a Pico W5, it works with the same setting)
💡 Step 5: Open and Upload Blink Example
  1. Go to: File > Examples > 01.Basics > Blink
  2. Click the Upload arrow (top left)
The onboard LED should start blinking once the code is uploaded.
💬 Final Notes:
  • The onboard LED is usually on GPIO 25
  • Works with both Arduino and MicroPython
  • For MicroPython, you can use Thonny or uPyCraft IDE
24.9k
18
  • Like( 18 )
