Bertrand Selva
Acoustic Targeting Module for Tactical Drone
This project presents a compact system capable of determining the direction and elevation of a sound source in real-time with Pi PICO
This project showcases a compact system that determines the direction and elevation of a sound source using a Raspberry Pi Pico. Equipped with four analog microphones arranged on a 3D-printed spherical frame, the device captures audio signals to compute the Time Difference of Arrival (TDOA). By applying Fast Fourier Transforms (FFT) and cross-correlation in the frequency domain, it efficiently calculates time delays between microphone pairs. These delays reference a precomputed lookup table to ascertain the sound's origin, which is then displayed on a 3.5-inch touchscreen.
The design emphasizes cost-effectiveness and computational efficiency, achieving real-time processing with minimal hardware. Applications span robotics, security, and environmental monitoring, demonstrating the system's versatility and practical utility.
Demonstration video here :
(please watch the video in the highest resolution to see the red arrow)
This project presents a compact, affordable system capable of determining the direction and elevation of a sound source using a Raspberry Pi Pico microcontroller.
Operational Mechanics
Upon detecting a sufficiently loud sound, the system:
  1. Captures audio signals from all four microphones.
  2. Applies Fast Fourier Transforms (FFT) to convert time-domain signals into the frequency domain.
  3. Computes cross-correlations between microphone pairs in the frequency domain using the formula:
    R(τ) = INV_F{F{x(t)} · F{y(t)}*}
    where F denotes the Fourier Transform, INV_F its inverse, and * indicates the complex conjugate.
  4. Identifies time delays by locating the maxima in the cross-correlation functions.
  5. Determines the sound source's direction by referencing a precomputed lookup table based on these delays.
  6. Displays the result on the touchscreen, indicating the direction with a graphical pointer.
This method offers computational efficiency with a complexity of O(n log n), suitable for real-time processing on resource-constrained hardware.
Demonstration
A demonstration video showcases the system's responsiveness, with processing times of just a few hundred milliseconds. The red LED indicates the processing phase, and the touchscreen provides immediate visual feedback on the detected sound direction. https://www.youtube.com/watch?v=_IeDw05at84
Limitations
  • Static Sound Sources: The system assumes stationary sound sources; moving sources can introduce inaccuracies due to unknown velocities.
  • Single Source Detection: Designed for single-source scenarios; multiple simultaneous sources may complicate localization.
Potential Enhancements
  • ESP32 Integration: Utilizing an ESP32 microcontroller with I2S ports and DSP capabilities can enhance performance and allow the use of MEMS microphones.
  • LoRa Communication: Implementing LoRa modules enables multiple units to communicate, facilitating triangulation over larger areas.
  • Drone Deployment: Mounting the system on drones can provide rapid, wide-area sound source localization.
  • Deep Learning for Sound Classification: Incorporating neural networks can allow the system to classify different sound types, such as distinguishing between gunshots, machinery noise, or human voices.
Applications
This low-cost, efficient system has potential applications in:
  • Robotics: Enhancing environmental awareness through sound direction detection.
  • Security: Detecting and localizing unusual sounds in surveillance scenarios.
  • Search and Rescue: Locating individuals in distress through sound cues
Not for commercial use – © Selva Systems – Contact for license
5.5k
19
  • Like( 19 )
