Budhi Prayoga
Monitoring Water Quality of Koi Fish Pond Cultivation
This project aims to develop a real-time monitoring system for important water quality parameters such as temperature, turbidity (TDS & turbidity), and pH. The device utilizes sensors such as DS18B20, SEN0244, SEN0189, and pH 4052c, integrated with a WiFi-based Robotdyn Arduino Uno microcontroller, and displays data in real-time via the IoT platform Thinger.io. This system not only displays data on an LCD screen, but can also be accessed from anywhere via a cloud dashboard, and data can be downloaded at any time. Testing was conducted over 7 days and the results showed a fairly good level of accuracy and precision, as well as compliance with the BBPBAT Buleleng koi pond water quality standards. Perfect for those interested in IoT, aquaculture, agricultural automation, or electrical engineering thesis projects! ???? Jangan lupa like, follow, dan comment..
  • Robotdyn Arduino Uno R3 Built-in WiFi with ESP8266
  • Power Supply Adaptor 12V 2A
  • DFRobot Analog TDS Sensor Meter for Arduino
  • DF Robot Turbidity Sensor
  • DFRobot Gravity Analog pH Sensor Meter
  • DS18B20 Temp Sensor Waterproof
  • LCD 20x4 Blue Light
  • i2c Module LCD Backpack 20x4
  • Passive Buzzer speaker Module 5V + Breakout pin header
  • Active Buzzer Module 5V + Breakout pin header
  • Bi Color LED 3mm (Red, Blue)
  • Holder LED cap plastik bracket lampu Led 3mm
  • Rocker Switch 3 Pin KCD1 Merah 220v 13x95mm
  • Fuse Holder Kecil 5x20mm 10A FH043
  • Fuse tabung 3A 300mah Sekring kaca fuse 5x20mm 250V
  • Kabel AC Jack Angka 8 1.5M 2.5A Power Cord
  • CableTies 15cm 100pcs Tali Nylin 150mm - Black
  • GX12 Jack Aviation Plug Socket Konektor GX-12 12mm Male Female 2
  • Spacer M3 5mm Gold Hex 0.5cm Male to Female with Screw and Nut
  • Fan Mini DC 12V 4x4x1CM 3p
  • Kabel Jumper Dupont Male to Female 20cm (10pcs)
  • Kabel Jumper Dupont Male to Male 20cm (10pcs)
  • Kabel Jumper Dupont Female to Female 20cm (10pcs)
  • AC Inlet Socket Angka 8 Tembaga
  • Kaki Box Universal Karet Buat Box X8
  • Black Box Plastic ABS Project Universal Box X8
  • Dissolved Oxygen Analyzer DO Tester Oksigen Water Quality Meter
  • Connector Housing 3 Pin (Sensor Turbidity)
  • RP-SMA Female to U.FL / UFL Cable 10cm Pigtail Antenna WiFi Kabe
  • Raspberry Pi Specified DC Brushless Cooling Fan AF28 30x30mm
  • Tang Potong Plato
  • PH TDS EC TEMP Meter Water Quality Tester 4 in 1 Function EZ-990
  • SolidWorks
  • Luxion Keyshot Rendering
  • Fritzing
Water quality is a critical factor in the successful cultivation of koi fish, where parameters such as temperature, turbidity (TDS and turbidity), and pH must be maintained within optimal ranges to ensure fish health and growth. Unmonitored changes in water conditions can lead to stress or even mass mortality. Therefore, a reliable, real-time, and remotely accessible monitoring system is essential to assist fish farmers in effectively managing pond water quality.
This research aims to design and develop an Internet of Things (IoT)-based water quality monitoring system for koi fish ponds capable of measuring temperature, Total Dissolved Solids (TDS), turbidity (NTU), and pH in real time. The system utilizes a Robotdyn Arduino Uno microcontroller integrated with an ESP8266 WiFi module, along with sensors: DS18B20 (temperature), SEN0244 (TDS), SEN0189 (turbidity), and pH 4052c. Sensor data is processed by the microcontroller and displayed locally on a 20x4 I2C LCD screen, while simultaneously being transmitted to the Thinger.io IoT platform for remote visualization via a real-time dashboard accessible from any internet-connected device.
The device was tested continuously over 7 days and compared against a reference instrument, the Water Quality Meter EZ9908. The results showed good levels of precision and accuracy. For temperature, precision ranged from 76.64% to 92.83% and accuracy from 73.73% to 96.42%. For TDS, precision was between 81.75% and 90.22%, with accuracy from 70.61% to 93.15%. For pH, precision reached 91.50%–95.04%, and accuracy ranged from 85.97% to 100.50%. All measured parameter values were within the acceptable range according to BBPBAT Buleleng standards for koi fish pond water quality.
The system is designed to be portable, plug-and-play, and cost-effective. Measurement data is stored in a cloud-based database and can be downloaded at any time. Although limitations exist—such as data retention limits on the free Thinger.io account (data loss after more than 99 readings)—the system has proven to be an efficient and modern solution for koi fish farmers.
In conclusion, the developed IoT-based monitoring system successfully integrates sensor technology and wireless connectivity for accurate, real-time, and remote water quality monitoring. Future recommendations include upgrading to a premium IoT platform for better data logging stability and adding automated alert notifications when water parameters exceed normal thresholds.
  • Fritzing Schematic Diagram
    Skematik_Kit_Module_Ikan_Koi_Idol_bb_115249234468bc0412bb29c.pdf
    Download(8)
14.2k
19
2
  • Comments( 2 )
  • Like( 19 )
