For the starters running with Arduino, one of the most common troublesome problems is their lack of comprehensive knowledge in module connecting. The Crowtail Starter Kit is designed and perfect for such starters. If you are also a starter and hoping to get into Arduino amazing world quickly, the Crowtail Starter Kit can be your perfect choice! With this Crowtail starter kit, you can easily dig into the Arduino world and immediately start with your own Arduino project!
Crowtail
For the very question of “which microcontroller for your electronic fashion”, Elecrow’s answer is the Larduino_mini!
Larduino Mini is a new Arduino mainboard compatible with original Arduino interfaces. Larduino Mini compatible to Arduino existing program, shield and IDE.
Are you still annoyed&puzzled by the variety of electronic components? Have you ever been rejected by the supplier because of small quantity you need? Good news, after long term prepared, Components Sourcing Service in Elecrow is available! Regardless of the quantity you want, you can purchase 10pcs or 10000pcs via this service now.
Elecrow, which located ShenZhen special economy zone, has the advantage on electronic components sourcing. We can provide you variety of components with high quality and competitive prices through various channels. From the resistance, capacitance, and inductance, diode and triode, rectifier bridge, IC to each type of connector, shell, wire/cable and button, we can help you to sourcing all of them. The service's aim is to save your money and time, so that
