Dharani Creations
Arduino‑based Smart Home Automation System
This project uses an Arduino Uno to integrate smoke, flame, light (LDR), rain sensors, an LCD display, and a buzzer to monitor environmental conditions. Alerts are triggered via the buzzer and real‑time statuses are displayed on the screen.
  • Arduino UNO
    X 1 fenxiang
  • Crowtail- Gas Sensor(MQ3) 2.0
  • IR Flame Detector module
  • LDR
  • 16×2 LCD Display Green Backlight
  • Buzzer
  • Jumper Wires
  • Breadboard
  • Fritzing
Project Title:
Smart Environmental Monitoring & Alert System Using Arduino
Detailed Project Description
Objective:
The goal of this project is to design and build a smart monitoring system using an Arduino Uno that can detect smoke, fire, ambient light, and rainfall, while displaying real-time status on an LCD and triggering a buzzer for immediate alerts. This system enhances safety and environmental awareness for homes, greenhouses, or remote installations.
Components Used:
Component Description
Arduino Uno The main microcontroller to process sensor data.
MQ-2 Gas Sensor Detects smoke, LPG, methane, and other gases.
Flame Sensor Detects presence of a flame using infrared light.
LDR (Photoresistor) Measures ambient light intensity.
Rain Sensor Module Detects presence and amount of rainfall.
16x2 LCD Display Displays real-time sensor status and messages.
Buzzer Sounds alerts when danger is detected.
Jumper wires & breadboard For connecting and testing components.
Power source USB or 9V/5V power supply for Arduino.
⚙️ System Working Principle:
 1. Smoke Detection (MQ-2 Sensor):
  • Continuously measures air quality for combustible gases and smoke.
  • When concentration exceeds a set threshold, the system:
    • Displays “Smoke Detected” on the LCD.
    • Triggers the buzzer.
 2. Flame Detection:
  • Detects IR radiation emitted by flames.
  • If a flame is detected:
    • The LCD shows “Flame Detected”.
    • The buzzer is activated as a warning.
 3. Rain Detection:
  • The rain sensor becomes conductive when wet.
  • On detecting rain:
    • Displays “Rain Detected” on the LCD.
    • Can be used to trigger a roof cover system or disable irrigation.
4. Light Detection (LDR):
  • Measures ambient light levels.
  • Displays light conditions such as “Bright”, “Dim”, or “Dark” based on calibrated analog readings.
5. Output Interface (LCD & Buzzer):
  • LCD (16x2): Continuously displays the status of all sensors.
  • Buzzer: Beeps when danger (flame or smoke) is detected.
Workflow Logic:
  1. Initialize all sensors and LCD in the Arduino setup() function.
  2. In the loop():
    • Read analog/digital values from all sensors.
    • Compare values with predefined thresholds.
    • Update LCD display based on sensor conditions.
    • Trigger buzzer if smoke or flame is detected.
    • Delay for readability and repeat the process.
Applications:
  • Fire & Smoke Alarm System
  • Automatic Weather Sensing for Smart Homes
  • Smart Irrigation Control (disable when raining)
  • General Home Safety & Monitoring
  • Outdoor Weather Stations or Greenhouse Automation
Advantages:
  • Low cost, open-source, and customizable.
  • Real-time visual and auditory alerts.
  • Modular – more sensors (like temperature, humidity) can be added.
  • Ideal for home safety, early fire detection, and environmental monitoring.
Limitations:
  • Rain sensor may be sensitive to humidity and needs waterproofing.
  • Flame sensor only detects open flames, not high temperature.
  • Calibration of MQ-2 may require real gas sources and proper tuning.
Future Enhancements:
  • Add Wi-Fi (ESP8266) or Bluetooth for wireless alerts.
  • Interface with IoT platforms (like Blynk, Thingspeak).
  • Include DHT11/DHT22 for temperature and humidity.
  • Integrate servo motors for automated window/roof control.
  • Add battery backup or solar power for remote use.
Conclusion:
This Arduino-based project offers a compact, efficient, and beginner-friendly implementation of a multi-sensor environmental safety system. It serves as a great starting point for students, hobbyists, and engineers interested in home automation, fire detection, and real-time monitoring.
  • GITHUB
    https://github.com/DharaniCreations/Arduino-based-Smart-Home-Automation-System.git
31.1k
17
2
  • Comments( 2 )
  • Like( 17 )
