Dharani Creations
Automatic night light sensor | Day OFF / Night ON
This project demonstrates a simple light-sensitive switch: it turns lights OFF during the day and ON at night. Ideal for street lights, garden illumination, or home automation.
  • LDR
  • BC547 Transistor
  • 12v Relay Module 10a
  • Resistors
  • Breadboard
  • 1N4007
  • Fritzing
Overview
Materials Required
  • LDR (Light Dependent Resistor / photoresistor)
  • BC547 (or equivalent) NPN transistor
  • Relay module (e.g. 12 V coil, SPDT)
  • Resistors (e.g., 10 kΩ, 330 Ω)
  • Zero PCB board or breadboard
  • Power supply (e.g. 9–12 V DC)
  • Diode (e.g. 1N4007) for back‑EMF protection
  • Optional: manual switch, LED indicator
Circuit Diagram
  • LDR forms half of a voltage divider, paired with a fixed resistor.
  • The voltage divider’s output is fed to the transistor base.
  • When it’s bright (day), the LDR resistance is low → base voltage low → transistor OFF → relay OFF → light OFF.
  • In darkness (night), LDR resistance increases → base voltage rises → transistor switches ON, activating the relay and powering the light.
Step-by-Step Instructions
  1. Construct the voltage divider: LDR + fixed resistor → center node to transistor base through ~1 kΩ resistor.
  2. Use BC547 as a switch: emitter to ground, collector to relay coil.
  3. Relay coil powered from 12 V; diode placed antiparallel across coil.
  4. Connect the relay’s output contacts to drive the external lighting circuit or LED.
  5. Power the circuit with a steady DC supply.
  6. (Optional) Add a manual override switch in series with load or relay.
Calibration & Tips
  • Adjust fixed resistor to set light/dark threshold; can use a potentiometer for tuning Arduino Forum.
  • Add hysteresis or time delay (e.g. via averaging or capacitor) to avoid flickering from passing shadows or clouds.
  • Install LDR away from the controlled light source to prevent feedback switching.
Example Arduino Variant
Some variations use an Arduino to read analog input from LDR and control a relay with code thresholds (e.g., activate when LDR reading drops below ~700)
Applications
  • Street and outdoor lighting control
  • Automated garden lights
  • Emergency lighting systems
  • Home automation for energy saving
Safety Notes
  • When switching AC mains, take proper insulation precautions or use a solid‑state relay.
  • For DC loads, ensure transistor and relay ratings are adequate.
  • Always include a flyback diode across relay coils to protect transistor.
Troubleshooting
Issue Solution
Light stays ON in day LDR may be shaded; increase sensitivity threshold or clean sensor
Lights flicker intermittently Introduce time delay or hysteresis in design
Relay chatter/clicking often Check power stability; use proper decoupling and delay
Transistor overheating Ensure base resistor value correct; check transistor ratings
  • Diagram
    Download(43)
  • Github Project
    https://github.com/DharaniCreations/Automatic-night-light-sensor/tree/main
  • You Tube
    https://youtu.be/j17iE2s1JKE
18.0k
18
2
  • Comments( 2 )
  • Like( 18 )
