Dharani Creations
Motion detection security system using pir sensor
This DIY system is designed to detect motion using a PIR sensor and notify the user via the Blynk mobile app. It uses a NodeMCU (ESP8266) as the core IoT microcontroller, connecting wirelessly to your home network to send real-time alerts whenever motion is detected
  • NodeMCU
  • crowbits-pir-sensor
  • 12v SMD Buzzer
  • Jumper Wires
  • Fritzing
  • Blynk
Project Overview
 Key Components
  • NodeMCU (ESP8266) – Wi-Fi-enabled microcontroller
  • PIR Sensor (e.g., HC‑SR501) – Detects infrared changes from movement
  • LED indicator – Visual feedback on detection
  • Buzzer (optional) – Audible alarm on motion detection
  • Smartphone with Blynk App – For remote notifications
 How It Works
  1. PIR Sensor monitors infrared radiation and outputs a digital HIGH signal upon detecting motion within its field of view (~3–7 meters, ~110°) .
  2. NodeMCU reads this digital signal on a GPIO pin. If level-shifting is needed (5V → 3.3V), a voltage divider is used.
  3. Upon motion detection:
    • LED lights up (e.g., red for alert, green for idle).
    • Buzzer starts beeping (if included).
    • A push notification is sent via the Blynk app to the user’s smartphone .
 Circuit Layout
  • PIR Sensor → NodeMCU digital input (example: D1/GPIO5), with power (VCC, GND)
  • LEDs → NodeMCU output (e.g. D7/GPIO13) via 220 Ω resistor (one LED for normal state, another for alert)
  • Voltage Divider (if needed) to ensure safe voltage levels between PIR output and NodeMCU input
 Software & Blynk Integration
  1. Setup in Blynk App:
    • Create a project using NodeMCU as the device.
    • Network type: Wi-Fi.
    • You’ll receive an Auth Token via email.
    • Add widgets: Toggle switch (e.g., to enable/disable monitoring) and Notification widget .
  2. Arduino Code:
    • Connect NodeMCU to Wi-Fi using SSID, password, and Auth Token.
    • Regularly read PIR input:
      • If HIGH → update LED/buzzer → send Blynk.notify("Motion detected").
      • If LOW → reset indicators accordingly.
    • Add debouncing or timers to avoid frequent alerts.
 Project Benefits & Applications
  • Use Cases:
    • Low-cost home or office security alert system
    • Room occupancy sensing
    • Motion-triggered LED or alarm activation
  • Advantages:
    • Affordable and accessible for beginners
    • Wireless (Wi-Fi) operation via NodeMCU
    • Real-time app notifications anywhere with internet access
    • Easily extendable for SMS, email, or camera integrations
 Summary Table
Feature Description
Detection Range PIR sensor ~3–7 m, ~110° field of view
Microcontroller NodeMCU ESP8266 (3.3 V logic, built-in Wi-Fi)
Alert Mechanisms LED, buzzer, push notification via Blynk
Connectivity Wi-Fi network and Blynk cloud
Best For Basic motion alert systems via smartphone
 Extensions & Enhancements
  • Send SMS or email alerts using WebHooks/API integration
  • Attach a camera (ESP32-CAM or similar) to capture snapshots on motion
  • Integrate with cloud dashboards or databases for longer-term logging
  • Automate alarms, lights, or voice announcements upon detection
In conclusion, this project offers a straightforward and practical approach to building a motion detection alert system using NodeMCU, PIR sensor, and the Blynk platform. It's ideal for learning IoT fundamentals, sensor interfacing, and remote monitoring.
  • CODE
    https://github.com/DharaniCreations/Motion-detection-security-system-using-pir-sensor/blob/main/arduino%20code.txt
  • Diagram
    https://github.com/DharaniCreations/Motion-detection-security-system-using-pir-sensor/blob/main/Circuit%20diagram.png
36.5k
17
  • Like( 17 )
