Grovety
  • 21 Projects
  • 22 Followers
  • Apr 08,2025
Open AI Terminal
OpenAI Terminal is an AI-powered voice assistant designed for the Elecrow CrowPanel Advance. It enables real-time communication with OpenAI models via WebRTC, providing hands-free interactions. Users connect via Wi-Fi, authenticate with an OpenAI API key, and access features like live transcriptions and model responses.
Open AI Terminal
It enables real-time communication with OpenAI, providing hands-free interactions.
A user asks a question or speaks a phrase using the microphone embedded in the CrowPanel. The audio is transmitted to OpenAI, where it is recognized. The recognized query is sent back and displayed on the screen. OpenAI then generates a response and sends it to the CrowPanel.
Example of interaction:
 🌐 Language Support
This Open AI Terminal supports multiple languages out of the box, including:
  • 🇺🇸 English
  • 🇨🇳 Chinese
  • 🇩🇪 German
  • 🇷🇺 Russian
  • 🇪🇸 Spanish
🔤 Other languages are also supported, but please note that correct character rendering on the display is not guaranteed for all scripts.
Which language characters would you like to see fully supported?
Let us know — we’re open to adding more!
Tutorial
Software
The fastest way to get started is to flash the board with the preloaded firmware — it only takes about 3 minutes:
1.    Download all files from the "binaries" folder: https://github.com/Grovety/CrowPanel_OpenAI/tree/main/firmware
2.    Download the archive with the flashing tool and extract its contents to the same folder where the binaries folder is located.
3.    Connect your CrowPanel to the computer.
4.    Run FlashTool.exe.
Or use the repository  https://github.com/Grovety/CrowPanel_OpenAI to make modifications.
Settings
Connect via Wi-Fi
OpenAI Key
Be careful and avoid mistakes. Entering the key can be a bit tedious due to its length, but it only needs to be done once — the panel will store it in memory.
Updates:
23/04/2025
We’ve slightly updated the interface by adding a large microphone activation button. This helps prevent it from picking up background conversations.
  • https://github.com/Grovety/CrowPanel_OpenAI
Open AI Terminal
3.7k
33
5
  • Comments( 5 )
  • Like( 33 )
  • Hi, your project is also suitable for our 'AI & Open Hardware' contest. Are you interested in participating? No need to upload again, just add this category :)
    Apr 14,2025 2 comments
    • Doreen Tn 2025-04-14 11:28:12
      Reply@Doreen Tn
      'AI & Open Hardware' Contest : https://www.elecrow.com/ai-open-hardware-contest.html
      Reply
    • Grovety 2025-04-14 22:05:39
      Reply@Doreen Tn
      Hey, awesome — thanks! Just added the category
      Reply
    Reply
  • Updates: We’ve slightly updated the interface by adding a large microphone activation button. This helps prevent it from picking up background conversations.
    Apr 23,2025 0 comments
    Reply
  • cool
    Mar 02,2026 0 comments
    Reply
