Luc Paquin
  • 76 Projects
  • 15 Followers
  • Feb 02,2025
Project #15: Environment – EEPROM – Mk25
https://www.donluc.com/?p=4289
https://youtu.be/u4PhQaekzQA
https://learn.dfrobot.com/makelog-314911.html
#DonLucElectronics #DonLuc #Arduino #EEPROM #DHT11 #ASM #Display #Elecrow #Project #Patreon #Electronics #Microcontrollers #IoT #Fritzing #Programming #Consultant
EEPROM
EEPROM (Electrically Erasable Programmable Read-only Memory) is a type of non-volatile memory. EEPROM is a type of non-volatile ROM that enables individual bytes of data to be erased and reprogrammed. That is why EEPROM chips are known as byte erasable chips. EEPROM is usually used to store small amounts of data in computing and other electronic devices. It is used in computers, usually integrated in microcontrollers such as smart cards and remote keyless systems, or as a separate chip device, to store relatively small amounts of data by allowing individual bytes to be erased and reprogrammed.
DL2501Mk08
1 x Crowduino Uno - SD
1 x Crowtail - Base Shield
1 x Crowtail - Temperature and Humidity Sensor 2.0
1 x Crowtail - Rotary Angle Sensor 2.0
1 x Crowtail - Moisture Sensor 2.0
1 x Crowtail - I2C LCD
1 x Crowtail - LED(Green)
1 x Crowtail - LED(Yellow)
1 x USB Battery Pack
1 x USB Mini-B Cable
Crowduino Uno - SD
SCL - A5
SDA - A4
POT - A1
ASM - A0
LEDY - 7
LEDG - 6
ITH - 5
VIN - +5V
GND - GND
DLE-EEPROM-UID-UnoMk001
DLE-EEPROM-UID-UnoMk001.ino
getEEPROM.ino
setup.ino
DL2501Mk08p
DL2501Mk08p.ino
getDisplay.ino
getEEPROM.ino
getSoilMoisture.ino
getTH.ino
setup.ino
Electronics, IoT, Teacher, Instructor, R&D and Consulting
-Programming Language
-IoT
-Robotics
-Automation
-Machine Learning
-Artificial Intelligence (AI)
-RTOS
-Consulting
-Etc...
Follow Us
https://www.donluc.com/luc/
Web: https://www.donluc.com/
Don Luc
839
13
  • Like( 13 )
