Luc Paquin
  • 77 Projects
  • 19 Followers
  • Oct 16,2025
Project #15: Environment - GNSS GPS - Mk34
  • FireBeetle 2 ESP32-P4 AI
    DFRobot
  • Adafruit SHARP Memory Display Breakout - 1.3" 168x144 Monochrome
    Adafruit
  • Gravity: GNSS GPS BeiDou Receiver Module
    DFRotot
  • USB Battery Pack
  • USB 3.1 Cable A to C
    DFRobot
Web
https://www.donluc.com/?p=4564
Facebook
https://www.facebook.com/share/v/1EX66b24er/
YouTube
https://youtu.be/tz7YLELhnQ4
DFRobot
https://learn.dfrobot.com/makelog-315041.html
#DonLucElectronics #DonLuc #GNSS #IoT #Project #DFRobot #Fritzing #Programming #Electronics #Microcontrollers #Consultant
GNSS stands for Global Navigation Satellite System. The main GNSS systems include GPS, GLONASS, QZSS, and BeiDou. These satellite systems transmit signals to the earth, allowing the receiver to determine its own position by calculating the propagation time of the signals and the position of the receiving satellite, thus achieving functions such as positioning and navigation.
This GNSS BeiDou positioning module supports multi-satellite system joint positioning and provides high-precision, high-speed, and stable data such as longitude, latitude, time, and altitude. It is suitable for various outdoor positioning scenarios, such as vehicle positioning, item tracking, weather stations, and outdoor positioning.
This GNSS receiver module uses the GNSS positioning system and support satellite systems such as BeiDou, GPS, GLONASS, QZSS, etc. Compared with traditional single GPS positioning, joint positioning using multiple systems increases the number of visible and usable satellites, which improves positioning accuracy and speed. It can also achieve stable high-precision positioning even in complex environments, providing more accurate positioning data.
DL2510Mk01
1 x FireBeetle 2 ESP32-P4 AI
1 x IO Expansion Board
1 x Adafruit SHARP Memory Display Breakout - 1.3" 168x144 Monochrome
1 x Gravity: GNSS GPS BeiDou Receiver Module
1 x USB Battery Pack
1 x USB 3.1 Cable A to C
DL2510Mk01p
DL2510Mk01p.ino
getDisplay.ino
getEEPROM.ino
getGNSS.ino
setup.ino
-Programming Language
-IoT
-Robotics
-Automation
-Unmanned Vehicles Terrestrial,  Marine and UAV
-Machine Learning
-Artificial Intelligence (AI)
-RTOS
-Consulting
-Etc...
Follow Us
https://www.donluc.com/luc/
Web: https://www.donluc.com/
Don Luc
  • DL2510Mk01p
    DL2510Mk01p_112383588468efe2dfcb148.zip
    Download(0)
18.7k
15
  • Like( 15 )
