Pabec
  • 61 Projects
  • 9 Followers
  • Oct 28,2025
PunchThrough Bean i2c Oled
//    Bean OLED Test Code                                        //
//#include <avr/pgmspace.h>
#include <Wire.h>
//---------------FONT + GRAPHIC-----------------------------//
#include "data.h"
// OLED I2C bus address
#define OLED_address  0x3c
//static int d0 = 0;
const int PWR_ON = 0;  //Using Pin 0 tp power the oleds VCC
  //pinMode(PWR_ON, INPUT_PULLUP);
  pinMode(PWR_ON, OUTPUT);
  digitalWrite(PWR_ON, HIGH);
  delay(1000);  //Needed!
  // Initialize I2C and OLED Display
  Wire.begin();
  init_OLED();
  delay(1500);
  reset_display();           // Clear logo and load saved mode
  char sz[]= "****";
  char ab[]= "****";
  uint16_t batteryV = 0;
  char tmp[5];
  displayOn();
   while(1)
    clear_display();
    sendStrXY("Temp:",0,4);
    float temperature = Bean.getTemperature();
    dtostrf(temperature,4,1,sz);
    sendStrXY(sz,1,4);
    batteryV = Bean.getBatteryLevel();
    sendStrXY("Bat Lev:",4,4);
    sprintf(tmp,"%d",batteryV);
    sendStrXY(tmp,5,4);
    sendStrXY("%",5,6);
    delay(5000);
    //reset_display();
    //digitalWrite(PWR_ON, LOW); //Display EN Off
    //Bean.sleep(2);
// Resets display depending on the actual mode.
static void reset_display(void)
  displayOff();
  clear_display();
  displayOn();
// Turns display on.
void displayOn(void)
    sendcommand(0xaf);        //display on
// Turns display off.
void displayOff(void)
  sendcommand(0xae); //display off
// Clears the display by sendind 0 to all the screen map.
static void clear_display(void)
  unsigned char i,k;
  for(k=0;k<8;k++)  //8
    setXY(k,0);
      for(i=0;i<128;i++)     //was 128
        SendChar(0);         //clear all COL
        //delay(10);
static void printBigTime(char *string)
  int Y;
  int lon = strlen(string);
  if(lon == 3) {
    Y = 0;
  } else if (lon == 2) {
    Y = 3;
  } else if (lon == 1) {
    Y = 6;
  int X = 2;
  while(*string)
    printBigNumber(*string, X, Y);
    Y+=3;
    X=2;
    setXY(X,Y);
    *string++;
// Prints a display big number (96 bytes) in coordinates X Y,
// being multiples of 8. This means we have 16 COLS (0-15)
// and 8 ROWS (0-7).
static void printBigNumber(char string, int X, int Y)
  setXY(X,Y);
  int salto=0;
  for(int i=0;i<96;i++)
    if(string == ' ') {
      SendChar(0);
    } else
      SendChar(pgm_read_byte(bigNumbers[string-0x30]+i));
    if(salto == 23) {
      salto = 0;
      X++;
      setXY(X,Y);
    } else {
      salto++;
// Actually this sends a byte, not a char to draw in the display.
// Display's chars uses 8 byte font the small ones and 96 bytes
// for the big number font.
static void SendChar(unsigned char data)
  Wire.beginTransmission(OLED_address); // begin transmitting
  Wire.write(0x40);//data mode
  Wire.write(data);
  Wire.endTransmission();    // stop transmitting
// Prints a display char (not just a byte) in coordinates X Y,
static void sendCharXY(unsigned char data, int X, int Y)
  setXY(X, Y);
  for(int i=0;i<8;i++)  //8
    Wire.write(pgm_read_byte(myFont[data-0x20]+i));
// Used to send commands to the display.
static void sendcommand(unsigned char com)
  Wire.beginTransmission(OLED_address);     //begin transmitting
  Wire.write(0x80);                          //command mode
  Wire.write(com);
// Set the cursor position in a 16 COL * 8 ROW map.
static void setXY(unsigned char row,unsigned char col)
  sendcommand(0xb0+row);                //set page address
  sendcommand(0x00+(8*col&0x0f));       //set low col address  //8
  sendcommand(0x10+((8*col>>4)&0x0f));  //set high col address  //8
  //Possible NEW!!
  //sendcommand((0x10|(col>>4))+0x02);
  //sendcommand((0x0f&col));
// Prints a string regardless the cursor position.
static void sendStr(unsigned char *string)
  unsigned char i=0;
  while(*string)
    for(i=0;i<8;i++)
      SendChar(pgm_read_byte(myFont[*string-0x20]+i));
    *string++;
// Prints a string in coordinates X Y, being multiples of 8.
// This means we have 16 COLS (0-15) and 8 ROWS (0-7).
static void sendStrXY( char *string, int X, int Y)
  setXY(X,Y);
  unsigned char i=0;
  while(*string)
    for(i=0;i<8;i++)
      SendChar(pgm_read_byte(myFont[*string-0x20]+i));  //0x20Hex=32Dec  128x64 or 64x48 48/2=24
      //SendChar(pgm_read_byte(myFont[*string-0x20]+i));
    *string++;
// Inits oled and draws logo at startup
static void init_OLED(void)
  sendcommand(0xa6);            //Set Normal Display (default)
    // Adafruit Init sequence for 128x64 OLED module
    sendcommand(0xAE);             //DISPLAYOFF
    sendcommand(0xD5);            //SETDISPLAYCLOCKDIV
    sendcommand(0x80);            // the suggested ratio 0x80
    sendcommand(0xA8);            //SSD1306_SETMULTIPLEX
    sendcommand(0x2F); //--1/48 duty    //NEW!!!
    sendcommand(0xD3);            //SETDISPLAYOFFSET
    sendcommand(0x0);             //no offset
    sendcommand(0x40 | 0x0);      //SETSTARTLINE
    sendcommand(0x8D);            //CHARGEPUMP
    sendcommand(0x14);
    sendcommand(0x20);             //MEMORYMODE
    sendcommand(0x00);             //0x0 act like ks0108
    sendcommand(0xA0 | 0x1);      //SEGREMAP   //Rotate screen 180 deg
    //sendcommand(0xA0);
    sendcommand(0xC8);            //COMSCANDEC  Rotate screen 180 Deg
    //sendcommand(0xC0);
    sendcommand(0xDA);            //0xDA
    sendcommand(0x12);           //COMSCANDEC
    sendcommand(0x81);           //SETCONTRAS
    sendcommand(0xCF);           //
    sendcommand(0xd9);          //SETPRECHARGE
    sendcommand(0xF1);
    sendcommand(0xDB);        //SETVCOMDETECT
    sendcommand(0x40);
    sendcommand(0xA4);        //DISPLAYALLON_RESUME
    sendcommand(0xA6);        //NORMALDISPLAY
  clear_display();
  sendcommand(0x2e);            // stop scroll
  //----------------------------REVERSE comments----------------------------//
  //  sendcommand(0xa0); //seg re-map 0->127(default)
  //  sendcommand(0xa1); //seg re-map 127->0
  //  sendcommand(0xc8);
  //  delay(1000);
  // sendcommand(0xa7);  //Set Inverse Display
  // sendcommand(0xae); //display off
  sendcommand(0x20);            //Set Memory Addressing Mode
  sendcommand(0x00);            //Set Memory Addressing Mode ab Horizontal addressing mode
  //  sendcommand(0x02);         // Set Memory Addressing Mode ab Page addressing mode(RESET)
   setXY(0,0);
  for(int i=0;i<128*8;i++)     // show 128* 64 Logo
    SendChar(pgm_read_byte(logo+i));
PunchThrough_Bean_i2c_Oled
More details: https://github.com/mike-rankin/PunchThrough_Bean_i2c_Oled. This is GitHub account: https://github.com/mike-rankin where you will explore more excellent projects. He is a good DIY maker who designs custom ESP32 IoT projects using Altium Designer, Arduino IDE and Fusion360. Welcome everyone to follow.
23.3k
13
  • Like( 13 )
