Bashir Saror
✈️ UAV Fixed Wing design– High-Lift Wing with Control Surfac
This model features the full wing structure of a precision agriculture UAV.
It includes:
✅ Wing surface with NACA 4412 airfoil
✅ Internal structure: spars, ribs, and stringers
✅ Control surfaces: flaps and ailerons
✅ Designed for modular spray integration and lightweight UAV construction
???? What’s Included
Parametric wing model (400 mm chord, rectangular planform)
Structural supports: dual main spars + ribs
Full-length flaps and ailerons with actuation cutouts
Designed for CFD, FEA, and aerodynamic optimization
???? Simulation Summary
✅ Wing-only CFD simulation performed
Lift at 8° AoA: ~370 N
Drag at 8° AoA: ~100 N
Aileron torque (20° deflection): ~198 Nm total (Z-axis)
Simulations show high lift at cruise (30 m/s), suitable for wide-area spraying
⚠️ Note on Stability
This file includes the wing only — fuselage and tail designs are not included.
If you plan to simulate static or dynamic stability, you’ll need to:
Design a fuselage pod
Establish a valid CG forward of the aerodynamic center
Optionally add horizontal stabilizers
???? Upcoming Release
Stay tuned for the full UAV assembly, including:
Fuselage pod with payload system
Boom-integrated spray mechanism
GPS & autopilot integration
Camera + mapping suite
14.5k
15
  • Like( 15 )
