LVGL stands for LittlevGL (Light and Versatile Graphics Library), a free, open-source graphics library that provides everything needed to create beautiful visual effects and small memory footprints for embedded GUI applications. Designed to be lightweight, efficient, and portable, LVGL is an ideal choice for resource-constrained devices such as microcontrollers.
3D printers have always been an option for adult makers, however, for kids keen on producing their own ideas, Toybox 3D printer has then stood out, 3D printers for kids now have become a new 3D printer commercial opportunity and can help kids establish 3D printing knowledge from a fairly young age, in this blog we'll introduce one of the most popular 3D printers for kids - the Toybox 3D printer.
The 3D printer extruder is a device that melts filaments (usually plastic) and extrudes them in a controlled manner to build a 3D printed object layer by layer. The 3D printer extruder is a critical component in the 3D printing process. It plays a very important role in determining the accuracy, speed, and quality of the printed object.
A DC 5V power supply is a type of power supply that provides a regulated and stable 5V DC (direct current) output voltage. This low-voltage power supply is commonly used to power electronic devices that require a 5V DC supply, including microcontrollers, sensors, LED lights, USB charging devices, and other low-power electronic components.
When it comes to mechanical keyboards, the printed circuit board assembly (PCBA) is a critical part that determines the performance and reliability of the keyboard. The PCBA is responsible for connecting the key switches to the controller and affects the keyboard's response time, input accuracy, and overall durability. Performing a PCBA test on a mechanical keyboard can help you identify potential connection problems and ensure that the keyboard is functioning properly. Elecrow has developed a specialized keyboard tester
We're excited to announce the upcoming crowdfunding campaign to be launched on crowd supply for the CrowVision 11.6-inch touch screen, which is designed for a range of single-board computers, including Raspberry Pi, LattePanda, Beaglebone, Jetson Nano, and more.
The micro-switch is a switch that operates rapidly with a very small amount of force. The micro-switch is also called a miniature snap-action switch. It is extremely reliable, fast, and efficient to operate, and is also known as a miniature snap-action switch. It is impossible to create smart appliances without micro switches. They are used in many modern-day smart applications. Microswitches are often used as safety devices because of their reliability and sensitivity. They are used to prevent the closing of doors when something or someone is in the way and other similar applications.
With its long-range and low-power capabilities, The Lora modules have become a popular choice for a wide range of IoT applications. But what are Lora modules, and what are their advantages and disadvantages? In this blog, we will explore everything you need to know about the Lora modules. Whether you are an IoT enthusiast, a technical professional, or a curious learner, this blog will provide you with a comprehensive guide to the fascinating world
Are you an electronics enthusiast looking to expand your electronics project repertoire? Want to take your skills to the next level by exploring new and exciting products? Look no further than our list of five cool electronics products from partner sellers!
Whether you're interested in building your own smart home devices, experimenting with sensors, or creating your own robot, these products are sure to inspire you. They cover a lot of application areas, from loop detectors used to monitor vehicle count in parking garages to Arduino CNC shields used in
The Protoboard, also known as a Protoboard, solderless Protoboard, or terminal array board, is a type of building platform used to create semi-permanent prototypes of electronic circuits without soldering. Protoboards can be used over and over again because they don't need to be soldered or have their tracks destroyed, which is completely different from a stripboard (veroboard). As a result,
