Mathivaanan A
ANPR Access Control PCB with IR Sensors
To control multiple RGB LEDs using fewer GPIO pins via a multiplexer (MUX), often for visual indication, lighting, or status feedback in IoT systems
  • Easyeda pro
1. Define Objective
  • Design a custom PCB for an ANPR vehicle access system.
  • Interface with Raspberry Pi 4 to control:
    • Traffic lights
    • Buzzer
    • Gate motor
    • RFID module
    • IR sensors for vehicle detection
2. Select Components
  • Headers (1x2, 1x4, 1x15, 3x1) – for modular connections
  • 5.5mm DC Jack – 12V power input
  • 1kΩ Resistors – for MOSFET gate pull-down
  • IRLZ44N MOSFET + Heatsink – for switching loads
  • Molex 48393-0003 Connector – secure 3-pin connections
  • IR Sensors – for detecting vehicle presence
  • Raspberry Pi 4 – main controller via GPIO
3. Design the PCB
  • Route 12V input and distribute power
  • Add headers for all peripherals (RFID, buzzer, lights, gate, IR sensors)
  • Connect MOSFETs to control high-current devices
  • Add GPIO header (1x15) for Raspberry Pi
4. Interface Raspberry Pi
  • Use GPIOs to:
    • Read IR sensor signals
    • Read RFID tag
    • Control gate, buzzer, and traffic light
  • Process ANPR camera feed over LAN
5. Manage Power
  • Input: 12V via DC jack
  • Output:
    • 12V for motors/lights
    • Optional 5V for logic-level devices (e.g., RFID, IR sensors)
6. Test System
  • Check individual components (IR, RFID, MOSFET switching)
  • Run Raspberry Pi code for full system logic
  • Validate vehicle detection, authentication, and gate control
7. Deploy System
  • Mount PCB and components securely
  • Connect to gate hardware and ANPR camera
  • Run live Python-based control from Raspberry Pi
34.5k
16
  • Comments( 1 )
  • Like( 16 )
