Ankur Majumdar
  • 2 Projects
  • 6 Followers
  • Feb 27,2026
Aqua Mitra – Smart Aquarium Dashboard using CrowPanel
Aqua Mitra is a smart aquarium companion built using the CrowPanel 2.8-inch ESP32 HMI display and SquareLine Studio. It provides an interactive touch dashboard to monitor and manage aquarium conditions in real time. The system integrates a DS18B20 temperature sensor for continuous tank monitoring, an SG90 servo motor for automated feeding at scheduled intervals, and relay-based control for lighting and air pump operation. By combining sensing, automation, and intuitive UI design, Aqua Mitra simplifies aquarium care while maintaining a stable and healthy aquatic environment through precise embedded control.
Aqua Mitra – Smart Aquarium Companion
Project Walkthrough -
       Video Link
Please watch this tutorial to understand the complete project:
https://youtu.be/XNOsKyu4lFM
About the Project
Aqua Mitra is a smart aquarium companion built using the CrowPanel 2.8” ESP32 HMI Display and SquareLine Studio. It provides an interactive touchscreen dashboard to monitor, manage, and automate essential aquarium operations.
The system integrates:
  • DS18B20 Temperature Sensor for real-time temperature monitoring
  • SG90 Servo Motor for automated fish feeding
  • Relay Modules for controlling aquarium lighting and water pump
  • Interactive UI designed using SquareLine Studio
This project focuses on combining embedded systems, UI design, and automation to maintain a stable aquatic environment and simplify fish care.
Aquarium Overview
This aquarium contains:
  • 20 fishes
  • 8 varieties:
    • Goldfish
    • Red Cap Goldfish
    • Tin Foil Barb
    • Neon Tetra
    • Rainbow Shark
    • Koi Carp
    • Angel Fish
    • Gourami
System Features
1️⃣ Fish Information Mode
  • View total number of fishes
  • Browse individual fish types
  • Learn general trivia:
    • Origin
    • Ideal temperature range
    • Required pH level
This helps in maintaining proper environmental conditions and improving fish health.
2️⃣ Feed Fish Mode
  • Manual feeding control via touchscreen
  • SG90 servo rotates to dispense food
  • Connected to GPIO 25
3️⃣ Tank Status Mode
  • Real-time temperature monitoring
  • Displays live tank conditions
  • Uses DS18B20 sensor connected to GPIO 23
  • Helps maintain stable water temperature to prevent fish stress
4️⃣ Control Panel Mode
  • Control aquarium lighting
  • Control water pump
  • Relay-based switching system
Technical Section
Link To The Playlist
Referred This Playlist To Understand and implement.
Learning References -
The Main lectures and Lesson 8 and Lesson 9 in Which It is thoroughly explained how to connect a servo motor and a temperature sensor.
CrowPanel 2.8" ESP32 HMI Display
  • Resolution: 480 × 320
  • MCU Speed: 150–250 MHz
  • Flash: ≤ 4MB
⚙️ Components Used
SG90 Servo Motor
Connection:
  • VCC → 5V
  • GND → GND
  • Signal → GPIO 25
Connection:
  • VCC → 3.3V
  • GND → GND
  • Data → GPIO 32
  • 4.2kΩ pull-up resistor between VCC and Data pin
Relay Modules
  • Used for light and water pump control
  • Controlled through ESP32 GPIO pins
Wiring Overview
Servo Motor (SG90)
  • Signal → GPIO 25
  • VCC → 5V
  • GND → GND
DS18B20
  • Data → GPIO 32
  • VCC → 3.3V
  • GND → GND
  • 4.2kΩ resistor between Data and VCC
 Future Improvements
Due to limited development time, the current focus was on UI and core functionality. However, future expansions may include:
  • Water Turbidity Sensor
  • TDS Sensor (Total Dissolved Solids)
  • IoT-based remote monitoring
  • Historical data logging
  • Mobile app integration
Programming
Note:
Please download the complete source code from the attached ZIP file in the repository assets.
SquareLine Studio UI
  • Entire UI built under 2MB storage
  • Optimized for embedded performance
  • Exported UI files integrated with Arduino .ino file
 Performance Parameters
Parameter Value Category
Resolution 480 × 320 Easy
Flash Memory ≤ 4MB Hard
Average FPS > 20 FPS Hard
MCU Speed 150–250 MHz Average
Difficulty Multiplier Overview
  • High FPS on limited flash storage
  • Efficient memory optimization
  • Real-time UI responsiveness
  • Hardware-software integration complexity
Display Datasheet
Why This Project Matters
Maintaining aquarium stability is critical for fish survival. Sudden temperature changes, improper pH levels, or irregular feeding schedules can cause stress and disease.
Aqua Mitra demonstrates how embedded systems, UI engineering, and automation can be combined to:
  • Improve fish safety
  • Reduce manual intervention
  • Increase reliability
  • Provide an intuitive user experience
  • Main Code Arduino IDE
    Aqua_Mitra_-_Project_190792057669a09e7d42736.zip
    Download(16)
  • Square Line Studio - Project Files
    Aqua_Mitra_-_Square_Line_Studio_176794237569a09eaf22e41.zip
    Download(14)
  • Elecrow HMI Display - Pin Layout
    Download(13)
1.8k
31
18
  • Comments( 18 )
  • Like( 31 )
