Dharani Creations
Arduino Alcohol Detector
This DIY electronics project showcases how to create a simple alcohol sniffing device using an Arduino and an MQ‑3 gas sensor. The system detects alcohol vapors in the environment—commonly used for breathalyzer-style applications—and provides immediate readings and visual feedback
  • ARDUINO NANO V3 ATMEGA328P CH340G 5V BOARD TYPE-C
  • Crowtail- Gas Sensor(MQ3) 2.0
  • LED Diffused Round
  • 12v SMD Buzzer
  • PCB POLOS DOUBLE LAYER FR4 FIBER 10X15CM
  • Fritzing
Project Overview
This DIY electronics project showcases how to create a simple alcohol sniffing device using an Arduino and an MQ‑3 gas sensor. The system detects alcohol vapors in the environment—commonly used for breathalyzer-style applications—and provides immediate readings and visual feedback.
 Objectives & Purpose
  • Design and build a breath alcohol detection system
  • Read alcohol levels via the MQ‑3 sensor
  • Display results to users through LEDs and serial output
  • Demonstrate sensor interfacing and basic data thresholding
 Key Components
Component Description
Arduino Uno/Nano Acts as the microcontroller base
MQ‑3 Gas Sensor Detection of alcohol vapor
LEDs Example: green for safe, red for alcohol alert
Buzzer (optional) Audible alarm when threshold crossed
Resistors For LED current limiting
Jumper Wires For connections
Breadboard Optional, for prototyping
 How the System Works
  1. MQ‑3 sensor measures alcohol concentration in breath via changes in analog output voltage.
  2. Arduino's analog input pin (e.g., A0) reads the sensor voltage.
  3. The code processes analog values:
    • If it exceeds a threshold → LED turns red + optional buzzer triggers.
    • Else → LED stays green.
  4. Serial Monitor output shows real-time sensor voltage values (for debugging and calibration).
 Wiring & Connections
  • MQ‑3 Sensor:
    • VCC → 5V
    • GND → GND
    • AOUT → Arduino A0
  • Green LED:
    • Anode → Arduino digital pin (e.g. D8) via resistor
    • Cathode → GND
  • Red LED (Alert):
    • Anode → Arduino digital pin (e.g. D9) via resistor
    • Cathode → GND
  • Buzzer (Optional):
    • One terminal → Arduino digital pin
    • Other terminal → GND
 Sample Arduino Sketch
cpp
const int sensorPin = A0; const int greenLED = 8; const int redLED = 9; const int buzzer = 10; // Optional const int threshold = 300; // Calibrate for your environment void setup() { Serial.begin(9600); pinMode(greenLED, OUTPUT); pinMode(redLED, OUTPUT); pinMode(buzzer, OUTPUT); digitalWrite(greenLED, HIGH); // default safe indication digitalWrite(redLED, LOW); } void loop() { int sensorValue = analogRead(sensorPin); Serial.println(sensorValue); if (sensorValue > threshold) { digitalWrite(redLED, HIGH); digitalWrite(greenLED, LOW); digitalWrite(buzzer, HIGH); // if included } else { digitalWrite(redLED, LOW); digitalWrite(greenLED, HIGH); digitalWrite(buzzer, LOW); } delay(500); }
???? Adjust threshold based on your calibration experiments (monitor serial output while testing with known ethanol sources).
 Applications & Extensions
  • Breathalyzer prototypes for educational purposes
  • Alcohol vapor detection in enclosed spaces
  • Calibration improvements using LCD/OLED displays
  • Bluetooth or Wi-Fi output for remote monitoring
  • Data logging to SD card or cloud services
 Key Learning Outcomes
  • Working with analog sensors and voltage-based thresholds
  • Interfacing the MQ‑3 gas sensor with Arduino
  • Using LEDs and buzzers for alerts
  • Calibrating sensors and interpreting analog data
 Safety & Calibration Notes
  • MQ‑3 sensors respond to both ethanol (alcohol) and certain volatile organic compounds—may give false positives if not calibrated
  • Always test in well-ventilated areas
  • Use small alcohol sources (e.g., diluted beverages) for testing—not direct ingestion
  • Be cautious with heating cycles and sensor warm-ups (usually requires several minutes to stabilize)
  • CODE
    https://github.com/DharaniCreations/Arduino-Alcohol-Detector/blob/main/Alcohol%20Detector.ino
  • Diagram
    https://github.com/DharaniCreations/Arduino-Alcohol-Detector/blob/main/1_bb.jpg
27.2k
17
  • Like( 17 )
