Kapacita22uF
  • 11 Projects
  • 14 Followers
  • Jul 15,2025
CH591D BLE5.4 USBC module
CH591D module- BLE5.4, USBC, RTC, ws2812b
Device Overview
The CH591D module-Bluetooth Low Energy (BLE) and USB-C connectivity, making it ideal for low-power wireless applications that also require USB communication .
Technical Specifications
Parameter Value / Description
Microcontroller CH591D
Flash 192+24+32 KB
RAM 24+2 KB
Bluetooth BLE 5.4
USB USB 2.0 Full Speed (via USB-C connector)
Power Supply 3.3 V (via USB-C )
USB Connector USB Type-C
Interfaces UART, , SPI, ADC, GPIO
ADC 4+1
GPIO 12
Programming Support ICP, ISP and IAP, support OTA wireless upgrade
Antenna PCB
Board Size 40*20mm
Connection & Pins
Fail:
- the description of Pb4 and Pb7 is reversed
Pin Function
USB-C Power and USB communication
VCC USB VBUS
GND Ground
RX / TX UART communication
PB7 BOOT
GPIOx Multi-function (ADC, SPI)
Use Cases
  • Wireless controllers or macro keypads( IMK8K )
  • Portable BLE-enabled gadgets
  • USB-HID device development
  • IoT modules with BLE notifications
  • Development and testing of BLE applications
Software Support
Programming Steps:
1. Preparation
  • Download and install MounRiver Studio from: https://www.wch.cn
  • Create a new project for CH591D:
    • File → New → Project → CH591
    • Select target chip: CH591D
2. Write Code
  • Write your C code (e.g., LED blink).
  • Make sure you have a main() function.
  • Save your .c file in the src directory.
    or
  • Download example
  • Unzip
  • Moun River Studio > Open existing project
  • Edit ...
  • Generating HEX File
    • Right-click your project in MounRiver → Build Project
    • The generated .hex file will be located at:
      ProjectFolder/output/ch591.hex
3. USB DFU Boot Setup
  • CH591D can be programmed over USB if PB7 is pulled to GND during power-up.Steps:
    1. Press and hold the button BOOT1 (PB7 = GND)
    2. Plug in the USB cable
    3. Release the button
  • The device will show up as WCHISP (depends on OS)
4. Uploading to Chip
  • In MounRiver go to: Tools → WCHISPTool
    Or use standalone WCHISPTool
  • Load the HEX file and click Download
  • The firmware will be flashed over USB
  • wchisp - WCH ISP Tool in Rust
  • wchisp -tested on Kubuntu:
    Quick Guide to Program CH591D with wchisp
    1. Install dependencies
    bash
    sudo apt install libusb-1.0-0-dev
    2. Install wchisp tool
    bash
    cargo install wchisp --git https://github.com/ch32-rs/wchisp
    3. Add udev rule (if not done yet)
    Create /etc/udev/rules.d/50-wchisp.rules with:
    sudo nano /etc/udev/rules.d/50-wchisp.rules
    SUBSYSTEM=="usb", ATTRS{idVendor}=="4348", ATTRS{idProduct}=="55e0", MODE="0666"
    (Ctrl+O, Enter, Ctrl+X)
    Reload rules:
    bash
    sudo udevadm control --reload-rules sudo udevadm trigger
    4. Connect CH591D via USB and check detection
    bash
    lsusb | grep 4348
    or
    bash
    dmesg | tail
    5. Check MCU info (verify access)
    bash
    wchisp info
    6. Flash hex/bin file
    Use absolute or relative path without leading ./:
    bash
    wchisp flash /path to/firmware.hex
Prototype Notice
NOTICE: This CH591D module is a development prototype. It may contain limitations, experimental firmware, or test components. Intended for development, debugging, and testing only.
6.3k
19
  • Comments( 1 )
  • Like( 19 )
  • Cool project.
    Dec 15,2025 0 comments
    Reply
