Mostafa Jamal
  • 4 Projects
  • 5 Followers
  • Oct 16,2025
OmniFire: Autonomous Fire-Fighting Robot with Mecanum Wheels
OmniFire is an intelligent autonomous robot capable of detecting and extinguishing fires using dual fire extinguishers, 12 ultrasonic sensors, and omnidirectional Mecanum wheels. Powered by an Arduino–Raspberry Pi hybrid control system, it combines precision motion, real-time environment mapping, and autonomous fire suppression for safety applications in homes, factories, and labs.
  • Mecanum wheel
    X 4
  • Arduino Mega TFT LCD Shield Adapter v2.2 for LCD 3.2" + Touchscr
    Tingkok, China
  • 10-liter water tank
  • fire extinguishers
  • 12 volt water pump
  • Arduino IDE, Python 3, Serial Library (PySerial), RPi GPIO Libra
  • Soldering Iron, Multimeter, Crimping Tool, Screwdriver Set
  • SolidWorks
  • Proteus or Fritzing (for wiring schematic)
 System Overview
OmniFire is a smart autonomous robot combining two powerful microcontrollers:
  • Arduino Uno for real-time sensor acquisition.
  • Raspberry Pi 4 for decision-making, communication, and actuation.
Both are connected via serial UART, forming a master-slave system. The Arduino reads 12 ultrasonic sensors and 2 IR sensors, sending structured data packets to the Raspberry Pi.
The Pi interprets these readings to control movement and the fire suppression system.
⚙️ System Architecture
  • Arduino → Handles low-level sensor data (12 ultrasonic + 2 IR).
  • Raspberry Pi → Processes incoming data, determines movement, and controls:
    • Two Cytron MD10C motor drivers (for four Mecanum wheel motors).
    • Relay module controlling the pump and dual solenoid valves.
  • Communication: Serial (9600 bps).
  • Power supply: 12 V battery + 5 V regulator for logic.
 Mecanum Wheel Control
The robot’s Mecanum drive enables full 360° motion — forward, backward, lateral, and diagonal — without rotating the body.
This allows OmniFire to precisely approach a flame from any angle.
Each wheel’s rotation and speed are controlled through the Cytron drivers using PWM signals from the Raspberry Pi.
 Sensor Layout
  • 12 Ultrasonic Sensors — 3 on each side (front, back, left, right).
    They create a full 360° obstacle detection map.
  • 2 Infrared Flame Sensors — Mounted front-left and front-right for directional fire detection.
(Refer to the included schematic diagram showing this layout.)
Fire Extinguishing System
  • A 10 L water/foam tank feeds two fire extinguishers mounted on the front.
  • Each extinguisher connects to a 12 V solenoid valve, which is relay-controlled by the Raspberry Pi.
  • When fire is detected and the robot reaches proximity, the Pi triggers:
    1. The solenoid valves to open.
    2. The pump relay to maintain pressure.
    3. After 3 seconds of spray, both are deactivated.
The dual extinguishers provide a wide-angle spray pattern for effective coverage.
 Operation Flow
  1. Scan: Arduino gathers ultrasonic and IR sensor readings.
  2. Communicate: Sends serial data packet like:
    <U1,U2,...,U12,IR1,IR2>
  3. Decision: Raspberry Pi interprets data, finds fire direction.
  4. Navigate: Mecanum motion adjusts position using distance mapping.
  5. Extinguish: Relays activate pump and solenoids.
  6. Resume Patrol: Robot resets and continues scanning.
 Example Arduino Code (Excerpt)
Serial.print("<"); for(int i=0;i<12;i++){ Serial.print(distance[i]); Serial.print(","); } Serial.print(IR_L); Serial.print(","); Serial.print(IR_R); Serial.println(">");
 Example Raspberry Pi (Python) Code (Excerpt)
import serial, RPi.GPIO as GPIO ser = serial.Serial('/dev/ttyUSB0', 9600) while True: data = ser.readline().decode().strip('<>\n') vals = data.split(',') if len(vals) >= 14: ir_left, ir_right = int(vals[-2]), int(vals[-1]) if ir_left == 1 or ir_right == 1: GPIO.output(pump, True) GPIO.output(solenoid, True) time.sleep(3) GPIO.output(pump, False) GPIO.output(solenoid, False)
 Applications
  • Fire safety demonstration robot.
  • Research prototype for industrial firefighting automation.
  • Mechatronics and robotics university projects.
  • Smart surveillance and safety systems.
 Key Features
  • Dual-controller (Arduino + Raspberry Pi) hybrid intelligence.
  • 12-sensor 360° obstacle awareness.
  • Omnidirectional Mecanum motion.
  • Real fire suppression with dual nozzles.
  • Modular design for scalability.
4.6k
22
  • Comments( 1 )
  • Like( 22 )
  • Cool project.
    Dec 15,2025 0 comments
    Reply
