A conventional loudspeaker converts an electrical audio signal into mechanical movement, and then into sound. Its main components are a permanent magnet, a voice coil, a diaphragm, usually a cone or dome and a flexible suspension. When the amplifier sends an alternating current through the coil, an electromagnetic force moves it back and forth. Because the coil is attached to the diaphragm, the diaphragm moves with it, and creates small variations in air pressure that travel outward as sound waves.
These types of loudspeakers are also known by several names, such as:
- Exciter-driven flat-panel loudspeaker
- Bending-wave panel speaker
- and Distributed mode loudspeaker (DML)
Detailed video at: https://youtu.be/uq6EsQIphE0
I will also perform testing and a comparison with a standard commercial speaker mounted in an appropriate sealed enclosure.
First, let’s look at the components of the panel speaker:
- There is this small device, known as a vibration resonant speaker,
- And a flat panel of specific dimensions, which needs to be rigid yet also sufficiently lightweight.
A vibration speaker is essentially a component of a conventional speaker, lacking a diaphragm and the flexible suspension typically found at the top of the diaphragm.
Only the lower yellow suspension (spider) is retained; however, instead of stiff fabric, a thin metal vibrating element made of elastic steel is used, with the coil attached to a metal surface. Subsequently, a panel is bonded to this surface.
The other part is a flat panel, which—as I emphasized earlier—must possess certain characteristics.
For this purpose, *Styrodur* (extruded polystyrene) or high-density expanded polystyrene (EPS) is most commonly used. These materials are used in the construction industry and are relatively inexpensive. In this project, I am using 1 cm thick high-density expanded polystyrene, which offers sufficient rigidity while being lighter than *Styrodur*. Much like with a conventional membrane, the material needs to be both rigid and lightweight.
Now I will move on to the manufacturing method: The final sound depends on the complete assembly: The panel's dimensions, thickness, stiffness, mass, and internal damping. Next, The exciter's position and mechanical characteristics, and from the adhesive connection. For a low-power speaker (as in this case), the recommended size is around 40x30 cm; however, through experimentation, I arrived at an optimal size of 30x20 cm. This dimension represented a compromise between the panel's physical size and the reproduction of low frequencies. Increasing the panel size (I tested a maximum size of 60x40 cm) resulted in only a marginal improvement in the low tones, while making the unit entirely impractical. Conversely, reducing the dimensions caused the low tones to weaken significantly, though this led to better reproduction of the upper-mid and high frequencies. This latter approach is useful when designing a speaker system that combines a woofer with a panel speaker.
The driver, or, more precisely, the vibration speaker must be firmly bonded to the panel in an asymmetrical position, at a specific, predetermined location.
This is approximately two-fifths of the way along the width and two-fifths of the way along the length. Positioning it this way helps avoid "dead spots" and resonances at the center. Although the manufacturer typically recommends suspending the panel from its top edge—with the driver attached, both practical experience and theory show that the best results are achieved when the body of the vibration speaker is bonded to a stable, rigid backing (in my case, a monitor mount). According to Newton’s Third Law, "for every action, there is an equal and opposite reaction."
Consequently, as the panel moves forward, the driver tends to move backward; this reduces the force applied to the panel, thereby diminishing the sound output. By securing the driver to a stable backing, the entire force, and thus the full motion, is effectively transferred to the panel.
Now, I will move on to the most interesting part: testing the speaker. This is what the fully assembled panel speaker looks like;
I will feed a signal from an audio amplifier into it via the connectors on the back. The small vibration driver has a power rating of 8 watts, so I need to be careful about how much power I supply to it.
As you could hear, the sound is relatively good—most frequencies are reproduced—but a primary limitation is that the audio in this recording is constrained by the camera's quality, making it difficult to fully capture the actual sound being produced. For this reason, I will connect another, conventional speaker—housed in a compression enclosure—so we can compare the sound from both sources. After this comparison, the sonic picture will become much clearer for those of you on the other side of the monitor.
Now, I will offer a brief, subjective analysis of what I have heard so far. I should emphasize right away that this is by no means high-end Hi-Fi sound. The midrange sounds a bit "muddled," while the high frequencies are relatively good, though somewhat rigid and over-emphasized. As for the low-frequency range, there is almost no deep bass; however, percussive instruments and the lower-midrange region are rendered excellently. In short, these types of speakers make an excellent choice for a desktop (PC) setup—especially if you are looking for a unique desk ornament that also serves a functional purpose (for instance, you could attach an artwork, an image, or a figure to the front panel).
Next, I will compare this panel speaker with another identical one, but with a smaller panel surface area.
Now the situation is different. As you can hear, this type of exciter-driven XPS panel with a relatively small panel size can quite effectively serve as a mid-high frequency driver, or even strictly as a high-frequency driver, within a given speaker system.
And finally a short conclusion. This DIY panel speaker project demonstrates that using an exciter driver on a lightweight polystyrene panel creates an efficient, unique alternative to conventional speakers, offering good midrange clarity and versatility for desktop setups. The compact design makes it an interesting DIY desktop speaker and a promising starting point for a system paired with a dedicated woofer.
