Issa Kanté
  • 1 Projects
  • 1 Followers
  • Oct 29,2025
Hydraulic Scissor Lift (Elevator)
Conception of a hydraulic scissor lift who is used to raise loads or people vertically using a crisscross mechanism powered by a hydraulic system
Hydraulic Transmission
As part of my mechanical engineering training, I worked on the study and design of a hydraulic scissor lift with the following specifications:
▪️ Capacity: 300 kg
▪️ Maximum height: 10 m
▪️ Lifting speed: 0.15 m/s
▪️ Lowering speed: 0.2 m/s
I. Functional Analysis
• FC0: Safely lift and lower a 300 kg load.
• Constraints: stability, speed control, operator safety, energy efficiency.
II. Chart of Purpose (Bête à cornes)
• Why? Safe work at height (access, maintenance, installation).
• What? People, tools, or loads ≤ 300 kg.
• Environment? Indoor workshop/site mainly, occasional outdoor use (wind, dust), stable ground.
III. Service Functions (FS)
• FS1 – Lift the load up to 10 m.
• FS2 – Hold the load without sagging.
• FS3 – Lower the load in a controlled manner.
• FS4 – Fine positioning (intermediate stops, smooth restarts).
• FS5 – Inform/alert (indicators, alarms).
IV. External Interactions (Octopus Diagram)
• Payload ↔ stability, center of gravity.
• Ground/support ↔ bearing capacity, flatness.
• Operator ↔ controls, safety.
• Power supply ↔ electrical/hydraulic.
▪️ Modeling & Simulation in SolidWorks:
I designed the system in 3D and validated its behavior through simulation.
This project allowed me to turn functional analysis, dimensioning, and virtual validation into a concrete technical solution.
  • Simulation
    https://www.linkedin.com/posts/issa-kante_solidworks30colpetition-solidworks-gaezniemaezcanique-activity-7388864993032564736-88RN?utm_source=social_share_send&utm_medium=member_desktop_web&rcm=ACoAAEZ2SBAB9Ju6TDK3QDyGAIeEZF0M9Fz5u1s
11.2k
17
  • Like( 17 )
