Azlan Shah
Icarus - ESP32-S3 Meshtastic Node
This project aims to produce a fully assembled Meshtastic node based on the ESP32-S3 and RA-01SH, both of which are avaliable for assembly by JLCPCB. The only components to be bought outside are the antenna and LiPo battery. The PCB will include battery charging and SMA connector. Meshtastic® is a project that enables you to use inexpensive LoRa radios as a long range off-grid communication platform in areas without existing or reliable communications infrastructure. This project is 100% community driven and open source! Meshtastic utilizes LoRa, a long-range radio protocol, which is widely accessible in most regions without the need for additional licenses or certifications, unlike HAM radio operations. These radios are designed to rebroadcast messages they receive, forming a mesh network. This setup ensures that every group member, including those at the furthest distance, can receive messages. Additionally, Meshtastic radios can be paired with a single phone, allowing friends
Additionally, Meshtastic radios can be paired with a single phone, allowing friends and family to send messages directly to your specific radio. It's important to note that each device is capable of supporting a connection from only one user at a time.
Board Features:
- ESP32-S3 N8R8 MCU (Bluetooth and Wi-Fi)
- MCP78731 Battery Charging, Load sharing and Battery protection
- BME280 Environment sensor (temperature, humidity and barometric pressure)
- RA-01SH LoRa module with SMA connector and 868mHz antenna
- SSD106 1.3" OLED
- Up, Down and Select buttons + BOOT and RESET
- USB-C
- Additional exposed GPIO for expansion e.g. GPS module.
Version 2:
- Replaces MCP73871 for BQ24074
- Adds on/off switch whilst allowing charging when off.
  • OSHWLab
    https://oshwlab.com/azlan777/icarus-v1
  • Version 2
    https://oshwlab.com/azlan777/icarus-v2
2.9k
17
  • Like( 17 )
