MrQ
  • 4 Projects
  • 3 Followers
  • Oct 05,2025
Motherboard for 3d printer using Rp2040 microcontroller
Motherboard for 3d printer that I designed myself
This is a motherboard using Raspberry pi RP2040 microcontroller with tmc2208 driver
The functions of this motherboard include:
- Reverse polarity protection.
- Expansion port for BLtouch.
- Can control up to 5 motors.
- Motor control driver is Tmc2208.
- 4 cooling fans including 3 24v fans and 1 pwm controlled fan.
- Hotend and bed are controlled by mosfet.
- Protection fuse is located at the 24v power supply, Hotend, Bed, Speaker.
- 5 logic switches to adjust the driver's operating mode
- The smd resistor often used to adjust the current limit has been replaced by a trimmer potentiometer which is more sturdy and easier to adjust
- To limit the current, I designed two holes for the user to measure directly from a multimeter.
- I added the Max98357 audio module that allows users to play sounds, music, not just melodies like other motherboards
- Due to the limitation of the number of Gpio pins, I have to share that pin with thermistor number 3 and two control pins of driver number 5, but I added a switch so you can switch between the two sound playback functions or add another driver.
- I use a 1.3 inch oled display module combined with an encoder module for control because I want to use I2c for communication to save pins
- Here is the product link: https://www.amazon.com/Display-Combined-Encoder-Interface-arduino/dp/B0DMYQHM9J
- This is a motherboard designed by me according to my preferences so it will not be compatible with existing firmware so I may have to find a way to tweak the firmware to suit it
- This is a project developed by me alone so there will be mistakes and limitations so I hope you will give me your comments in the comment section so I can improve further
27.7k
19
  • Like( 19 )
