Luc Paquin
  • 75 Projects
  • 15 Followers
  • Oct 30,2025
Project #16: Sound – ESP32 – Mk27
  • DFRobot FireBeetle 2 ESP32-E
    DFRobot
  • Fermion: 2.0" 320x240 IPS TFT LCD
    DFRobot
  • GDL Line 10 CM
    DFRobot
  • Gravity: IO Shield for FireBeetle 2
    DFRobot
  • Mini MP3 Player
    Elecrow
    X 1 fenxiang
  • Speaker
  • Gravity: Analog Rotation Potentiometer
    DFRobot
  • Gravity: Digital Push Button (Red)
    DFRobot
  • Lithium Ion Battery - 1000mAh
    DFRobot
  • Switch
  • USB 3.0 to Type-C Cable
    DFRobot
Web
https://www.donluc.com/?p=4577
Facebook
https://www.facebook.com/share/v/16zWXSQ9Ck/
YouTube
https://youtu.be/jTDHvMbpHGA
DFRobot
https://learn.dfrobot.com/makelog-315051.html
#DonLucElectronics #DonLuc #MiniMP3Player #FireBeetle2ESP32E #ESP32 #DFRobot #Display #IoT #Project #Fritzing #Programming #Electronics #Microcontrollers #Consultant
FireBeetle 2 ESP32-E, specially designed for IoT, is an ESP-WROOM-32E-based main controller board with dual-core chips. FireBeetle 2 ESP32-E supports Arduino programming, support Scratch graphical programming and MicroPython programming. We provide you with detailed online tutorials and application cases, and there are thousands of sensors with welding-free Gravity interfaces and actuators to help you get started easily. Besides, the stamp hole design makes it able to be easily embedded in your PCB, greatly saving your costs and time to build and test a prototype.
Digital push button with LED, wide voltage range, durable design, and easy plug-and-play functionality. Comes with a cable and features a gold surface.
Gravity: Analog Rotation Potentiometer Sensor
This Arduino-compatible rotation potentiometer rotates 300 degrees, allowing easy interaction and MIDI production with expansion boards; works on 3.3V-5V.
MP3
1.mp3 - William Shakespeare
2.mp3 - Albert Einstein
3.mp3 - Luc Paquin
4.mp3 - Carl Sagan
5.mp3 - Dalek
DL2510Mk03
1 x DFRobot FireBeetle 2 ESP32-E
1 x Fermion: 2.0" 320x240 IPS TFT LCD
1 x GDL Line 10 CM
1 x Gravity: IO Shield for FireBeetle 2
1 x Mini MP3 Player
1 x 1K Ohm Resistor
1 x Speaker
1 x Gravity: Analog Rotation Potentiometer
1 x Gravity: Digital Push Button (Red)
1 x Switch
1 x USB 3.0 to Type-C Cable
DL2510Mk03p
DL2510Mk03p.ino
getDisplay.ino
getEEPROM.ino
getMiniMP3.ino
setup.ino
-Programming Language
-IoT
-Robotics
-Automation
-Unmanned Vehicles Terrestrial,  Marine and UAV
-Machine Learning
-Artificial Intelligence (AI)
-RTOS
-Consulting
-Etc...
Follow Us
https://www.donluc.com/luc/
Web: https://www.donluc.com/
Don Luc
8.5k
12
  • Like( 12 )
