R4TKN
R4TKN BW16 Dual-Band Wi-Fi Deauth 2.4/5 GHz
R4TKN Deauther transforms the Ai-Thinker BW16 (RTL8720DN) into a dual-band 2.4/5 GHz Wi-Fi security lab tool, simulating disconnection events to audit and harden networks—featuring a portable, TFT-driven UI for authorized testing only.
  • 1.8inch IPS Display SPI HD 65K Full Color LCD TFT Module ST7735S
    X 1 fenxiang
  • BW16 KIT BW16 RTL8720DN BW12
    Ai-Thinker
  • 6x6 Tactile Micro Push Button
What is the project about?
R4TKN Ghost Deauther explores how clients and access points behave under management-frame stress. On the Ai-Thinker BW16 (RTL8720DN), your firmware demonstrates dual-band (2.4/5 GHz) behavior, UI on a small TFT, and button-driven modes to evaluate Wi-Fi resilience. The point isn’t to knock networks offline; it’s to study how protections (like 802.11w/PMF), WIDS/WIPS, and client stacks respond—so admins can harden their setups.
How does it work? (High level)
  • The device crafts or listens for 802.11 management frames (beacons, probe req/resp, deauth/disassoc).
  • The UI lets a tester choose a lab scenario and observe AP/client reaction latencies, retry patterns, roaming, and whether PMF is enforced.
  • Results inform mitigation: enable PMF, tune roaming thresholds, deploy WIDS policies, and educate users.
Why it matters to the community
  • Education: Makes radio-layer behavior visible and teachable.
  • Resilience testing: Helps teams confirm whether PMF and WIDS really catch management-frame anomalies.
  • Safety: Encourages consent-based, lab-only experimentation instead of blind trial-and-error in the wild.
  • Deauth per client / per station
  • Deauth all
  • Random SSID
  • Beacon + Deauth combo
Step 1 — Flash the board (before soldering)
Step 1.5 — Trim excess pins for fit (Optional)
Step 2 — Solder the BW16 onto the PCB
Step 3 — Solder the 3 × 6×6 tactile buttons
Step 4 — Solder the 1.8″ TFT (SPI)
  • R4TKN-FIRMWARE-BW16
    https://github.com/rusyln/R4TKN-FIRMWARE-BW16
6.6k
18
6
16
  • Comments( 6 )
  • Like( 18 )
  • Perfect Project.
    Sep 13,2025 1 comments
    • R4TKN 2025-09-15 09:46:54
      Thanks, wait for V3 it will be available here also at elecrow
      Reply
    Reply
  • how do you add a battery, so it can be more portable?
    Oct 23,2025 0 comments
    Reply
  • pcb gerber dosyasını alabilirmiyim gokkayailyas7@gmail.com mail adresine atabilirmisin
    May 13,2026 0 comments
    Reply
  • bide ölçü leri ve katman ölçüleri Paneldeki Farklı Tasarım Sayısı: Kalınlık: Yüzey Kaplama: Via Kaplaması: Bakır Kalınlığı: PCB Kenar Toleransı: PCB İşaretlemesi:
    Reply
  • gerber ücreti yazmışım dosyası olucaktı
    Reply
