Grovety
  • 21 Projects
  • 22 Followers
  • Apr 18,2025
Simple Weather Station on CrowPanel Advance
A ready-to-use weather station. Quick setup: flash the prebuilt firmware and start testing in under a minute, no coding required. Open-source and customizable for your own weather-based projects. Firmware and source code available on GitHub.
Goods
This is a lightweight, open-source weather station project designed for the CrowPanel Advance. It displays detailed weather information from openweather.com and is ready to test in under 1 minute.
✅ Quick Start in 2 Steps:
  1. Grab your CrowPanel Advance
  2. Flash the precompiled firmware from GitHub — no setup needed: https://github.com/Grovety/CrowPanel_OpenWeather/tree/main/firmware
💡 Why Use It?
  • Testable in under 1 minute
  • Open-source — extend or repurpose for your own weather-related projects
  • Simple and reliable — ideal for both hobbyists and developers
🌦️ Features:
  • Current temperature and “feels like” temperature
  • Cloudiness, wind speed, pressure, humidity
  • Sunrise and sunset times
  • Hourly forecast for the next 12 hours
  • Daily forecast for the next 4 days
  • NEW You can now change the city using voice commands
⚙️ Settings:
Temperature and pressure units (°C/°F, mmHg/hPa)
Manual and auto screen brightness control
Manual or automatic location detection
Wi-Fi connection setup via touch interface
👉 Precompiled firmware and source code are available on GitHub: https://github.com/Grovety/CrowPanel_OpenWeather/
New update:
Now you can check the weather in different cities using your voice instead of typing on a touchscreen. Just press and hold the button, say the name of the city, then release the button. The weather station will switch to the city you named, display the local time and weather, and then return to the default location after 10 seconds.
  • https://github.com/Grovety/CrowPanel_OpenWeather
4.4k
32
2
  • Comments( 2 )
  • Like( 32 )
  • How difficult is it for the person using it to add inches of mercury?
    Apr 25,2025 0 comments
    Reply
  • Cool
    Feb 28,2026 0 comments
    Reply
