Uchechukwu George
  • 2 Projects
  • 1 Followers
  • Sep 05,2025
Smart Plant Care Assistant – Arduino-Based Plant Monitor
Keep your plants healthy with this Arduino-based Smart Plant Care Assistant! This device monitors your plant’s soil moisture, light intensity, and ambient temperature, alerting you when your plant needs water or more light. Notifications are sent through an LED and buzzer, making plant care easy and fun. This project is beginner-friendly, yet visually appealing, perfect for plant lovers and Arduino enthusiasts alike.
Features:
  • Soil Moisture Monitoring: Alerts you when your plant needs watering.
  • Light Monitoring: Detects low light conditions for optimal plant growth.
  • Temperature Check: Monitors ambient temperature to ensure a healthy environment.
  • Visual and Audio Alerts: LED indicator and buzzer notifications.
  • Optional Enhancements: Add an OLED display or RGB LED for a high-tech look.
Components Needed:
Component Quantity Notes
Arduino Uno / Nano 1 Main microcontroller
Soil Moisture Sensor 1 Detects soil dryness
Light Sensor (LDR) 1 Measures ambient light
DHT11 Temperature & Humidity Sensor 1 Monitors environmental temperature
Small Buzzer 1 Audio alert
RGB LED (optional) 1 Visual alert
Jumper Wires As needed Connections
Breadboard or small PCB 1 Assembly
Circuit Diagram (Text-Based Overview):
  • Soil Sensor → Analog Pin A0
  • LDR Sensor → Analog Pin A1
  • DHT11 Sensor → Digital Pin 2
  • Buzzer → Digital Pin 3
  • LED → Digital Pin 4
  • Power → Arduino 5V and GND
  • Arduino
    elecrow_watch_nosolder_package_4467007768badb172f3ae.zip
    Download(31)
37.9k
17
  • Like( 17 )
