The Smart Plant Guardian is an IoT-enabled, self-sustaining plant care system that automatically monitors and maintains optimal growing conditions for your plants. It combines sensors, automation, and solar power to:
✅ Monitor soil moisture, temperature, humidity, and light levels.
✅ Automatically water plants when needed.
✅ Alert you via a mobile app if something’s wrong.
✅ Run on solar + battery power for eco-friendly operation.
Perfect for home gardeners, urban farmers, and electronics enthusiasts who want a hands-off approach to plant care!
System Overview
Sensors measure soil moisture, temperature, humidity, and light.
Crowduino (Arduino-compatible) processes data and decides when to water.
Water pump activates when soil is too dry.
WiFi (ESP8266) sends data to your phone via Blynk/MIT App Inventor.
Solar panel + battery keep it running without outlets.
Components Needed
| Component | Where to Buy |
| Crowduino (Arduino) | Elecrow |
| Soil Moisture Sensor | Elecrow/Amazon |
| DHT22 Sensor | Amazon/AliExpress |
| 5V Water Pump | AliExpress/SparkFun |
| ESP8266 (WiFi) | Elecrow/Amazon |
| 0.96" OLED Display | Elecrow |
| Solar Panel (5V 1W) | Adafruit/eBay |
Wiring Guide
| Component | Crowduino Pin |
| Soil Moisture Sensor | A0 |
| DHT22 Sensor | D2 |
| Light Sensor | A1 |
| Water Pump | D5 (via Relay) |
| ESP8266 (WiFi) | RX/TX (UART) |
Install Required Libraries
#include <DHT.h> #include <ESP8266WiFi.h> #include <Adafruit_SSD1306.h>
2. Main Logic (Simplified)
void loop() { int moisture = analogRead(A0); if (moisture < 30) { // If soil is dry digitalWrite(PUMP_PIN, HIGH); // Turn on pump delay(2000); // Water for 2 seconds digitalWrite(PUMP_PIN, LOW); } }
Option 1: Blynk (Easiest)
Download Blynk App (iOS/Android).
Create a project with:
Live Soil Moisture Gauge
Button for Manual Watering
Alert Notifications
Option 2: MIT App Inventor (Customizable)
Drag-and-drop UI with HTTP/MQTT for sensor data.
🔋 Step 4: Power & Enclosure
Solar Panel → TP4056 Charger → 18650 Battery
3D-Printed Case (Download STL Files)
Waterproof electronics compartment.
Modular sensor mounts.
Demonstration Video
▶️ Watch How It Works! (Link to YouTube demo)
💡 Why This Project Matters
Saves Plants from over/under-watering.
Teaches IoT, Sensors, and Automation in a practical way.
Open-Source & Hackable – add cameras, AI, or voice control!
⚠️ Common Pitfalls & Fixes
| Issue | Solution |
| Pump not turning on | Check relay wiring + power supply. |
| WiFi disconnects | Use stable 3.3V for ESP8266. |
| Wrong moisture readings | Calibrate sensor in dry/wet soil. |
