FUSION AUTOMATE
  • 20 Projects
  • 8 Followers
  • Oct 31,2025
Pico W MQTT: Publish Internal Temperature to HiveMQ
A MicroPython script for Raspberry Pi Pico W that reads the onboard temperature sensor and publishes the data to an MQTT broker over Wi-Fi.
This MicroPython program connects a Raspberry Pi Pico W to a Wi-Fi network and periodically publishes its internal temperature readings to an MQTT topic (pico/w/temperature) on the public HiveMQ broker. It uses the onboard ADC channel to read the internal temperature sensor, converts the analog value into Celsius, and sends it every 5 seconds via MQTT. The script demonstrates Wi-Fi connectivity, sensor data acquisition, and MQTT-based IoT communication — a foundational setup for remote monitoring or IoT data logging projects.
  • Micropython Code
    MQTT_Temperature_6351589006903a2c54bc7b.zip
    Download(8)
26.1k
18
  • Like( 18 )
