FUSION AUTOMATE
  • 20 Projects
  • 8 Followers
  • Nov 02,2025
Dual Slider LED Blink Controller using ESP32
A dual-slider ESP32 project that controls LED blink speed in real time using two analog slide potentiometers and a toggle switch with live LCD feedback.
  • Espressif ESP32 Development Board
  • Sliding Potentiometer
  • VS Code
???? Overview
This project demonstrates how to control an LED's blink rate in real time using two analog slide potentiometers and an ESP32.
A toggle switch is used to select which slider (A or B) is currently active, and a 16x2 LCD displays the active slider, its blink rate, and the inactive slider’s rate.
It’s a clean, practical project for learning analog input handling, non-blocking timing (millis), and LCD interfacing with ESP32.
⚙️ Features
  • Dual analog slide potentiometers (POT_A, POT_B)
  • Toggle switch for selecting the active slider
  • Real-time LCD display of blink rates
  • Non-blocking LED blinking using millis()
  • Fully functional on breadboard (no external libraries beyond LiquidCrystal)
???? Working Principle
  1. Each potentiometer outputs an analog voltage (0–3.3 V) read via ESP32 ADC pins.
  2. The values are mapped to a time delay range (50 ms – 500 ms).
  3. The toggle switch decides which slider controls the LED’s blink rate.
  4. The LCD shows the current active slider (marked with *) and the corresponding blink rate.
  5. The LED blinks using non-blocking logic, ensuring smooth updates and display refreshes.
???? Components Required
Component Quantity Description
ESP32 Dev Board 1 Main microcontroller
16x2 LCD (JHD162A) 1 Parallel interface LCD display
Slide Potentiometer (10 kΩ) 1 Analog input sliders
SPDT Toggle/Slide Switch 1 For slider selection
Jumper Wires — For connections
Breadboard 1 Circuit assembly
???? Pin Connections
Component Pin ESP32 GPIO
LCD RS — 12
LCD E — 13
LCD D4 — 14
LCD D5 — 27
LCD D6 — 26
LCD D7 — 25
POT A Output 34
POT B Output 35
Switch Output 33
LED + 2
LED – GND
LCD VCC — 5 V
LCD GND — GND
???? Core Concepts Used
  • Analog to Digital Conversion (ADC)
  • map() function for value scaling
  • Non-blocking delay using millis()
  • LCD interfacing (parallel mode)
  • State control with a toggle switch
???? Applications
  • Demonstrating analog control and feedback systems
  • DIY learning project for beginners in embedded systems
  • Adaptive LED indicators
  • Foundation for motor-speed or brightness controllers
  • Source Code
    https://github.com/AhirTech1/Dual-Slider-LED-Blinker.git
  • circuit-diagram
    Download(1)
18.7k
15
  • Like( 15 )
