FUSION AUTOMATE
  • 20 Projects
  • 8 Followers
  • Oct 30,2025
Wifi Clock using Nextion Discovery Series Display and ESP32
ESP32 + Nextion Display Pomodoro Clock — shows real-time time/date, runs a Pomodoro timer with adjustable duration, and uses a non-blocking LED alert when sessions complete.
  • ESP32 Development Board
  • Nextion 3.5" Discovery Series Resistive Touch Display
    Nextion
  • Nextion Display
    Nextion
⏰ ESP32 × Nextion Display — Smart Pomodoro Clock with Real-Time Display
A complete Nextion-powered Pomodoro and clock system built on ESP32. It combines real-time clock synchronization (via NTP), a fully interactive Pomodoro timer, and non-blocking LED alerts, all managed through a sleek touchscreen interface.
???? Overview
This project turns your Nextion HMI display into a productivity dashboard:
  • Displays current time, date, and day (synced from the internet).
  • Features a custom Pomodoro timer with start, stop, reset, and time adjustment.
  • Includes a non-blocking LED blink alert when the Pomodoro session ends.
All touch interactions are handled via raw Nextion serial packets — no external libraries needed.
⚙️ Features
✅ Real-time clock synced from NTP ✅ Dual-screen interface (Home & Pomodoro) ✅ Adjustable Pomodoro duration (1–60 mins) ✅ Start, stop, pause, and reset timer controls ✅ LED alert (non-blocking) after timer completion ✅ Robust Nextion event parser with noise filtering
???? Hardware Setup
Component Description
ESP32 Handles logic, NTP sync, and LED control
Nextion Display UI for clock & Pomodoro
Built-in LED (GPIO 2) Visual alert indicator
Wiring:
ESP32 Pin Nextion Pin Description
16 TX Display → ESP32
17 RX ESP32 → Display
5V 5V Power
GND GND Common ground
????️ Nextion Pages
Page 0 — Home Screen
Component ID Purpose
bLed 6 Trigger LED test (3s blink)
bPom 7 Go to Pomodoro page
tTime, tSec, tDate, tDay — Display time and date
Page 1 — Pomodoro Screen
bHome 3 Return to Home
bInc, bDcr 4,5 Adjust duration ±1 min
bStart, bStop, bReset 6–8 Timer controls
tTimer — Show countdown
???? Core Functionalities
???? Clock System
  • Wi-Fi + NTP-based time sync
  • Updates every second on Nextion
  • Shows hour, minute, second, date, and weekday
???? Pomodoro Timer
  • Default 25:00 minutes
  • Adjustable 1–60 mins
  • Non-blocking countdown
  • Smooth updates every second
  • State transitions: IDLE → RUNNING → PAUSED → ALERT
???? LED Alert
  • Blinks automatically after timer ends
  • 10-second non-blocking alert
  • Fully handled using millis() for multitasking
???? Code Architecture
Section Function
setupTime() Connects WiFi & syncs time
updateClockDisplay() Updates time/date/day on Nextion
runPomodoro() Handles countdown & transitions
runLedAlert() Manages non-blocking LED blinking
handleNextionEvents() Parses and processes touch events
???? Event Flow
  1. Home page loaded → Real-time clock updates every second
  2. User presses Pomodoro button → Switches to Pomodoro page
  3. Start button pressed → Timer begins counting down
  4. Timer ends → LED alert blinks for 10 seconds
  5. Back to Home → Clock display resumes
???? Libraries Used
  • WiFi.h
  • time.h
  • HardwareSerial.h
???? Highlights
  • Fully non-blocking system (no delay() used in logic loops)
  • Efficient, byte-level parsing of Nextion touch events
  • Modular functions — easy to expand with new pages or features
  • Includes Arduino and Nextion (HMI) files including images
    Wifi_Clock_56915653269031ba23190e.zip
    Download(25)
29.3k
16
  • Like( 16 )
