axstyle.design LastName
  • 2 Projects
  • 1 Followers
  • Oct 25,2025
Ax-Style Speaker Cabinet — Acoustic Optimized Housing two
A modern DIY wooden speaker that looks clean, sounds big, and is fun to build.
A modern wooden speaker cabinet designed for CNC milling and DIY audio projects.
This enclosure is made from 3 main parts: the front baffle, solid body shell, and rear cover — making it easy to machine, sand, assemble, and finish.
Internal driver pockets are shaped to improve mid-bass response and reduce unwanted resonance.
Symmetrical geometry also creates a clean visual rhythm suitable for industrial design studies or prototype speakers.
✅ Recommended CNC Setup
• Material: MDF, Birch plywood, Rubberwood
• Tooling: 6 mm end mill (roughing/profiling), 3 mm ball nose (curved features)
• Layer Steps: 2–3 passes depending on tool strength
• Sand: 240–400 grit
• Finishing: Matte lacquer, PU, oil coat
✅ Features
• Clean parametric geometry
• Easy to clamp and assemble
• Removable back plate for service and wiring
• Optimized pocket depth for speakers
✅ Assembly
• Wood glue or screws
• Add foam sealing for acoustic isolation
✅ Files Included
• STL — direct toolpath simulation
• JPG renders — reference visualization
(Optional: add STEP, DXF if you want more value later)
Design by AX-Style
1.4k
14
  • Like( 14 )
