Gabber Burgundo
  • 7 Projects
  • 2 Followers
  • Oct 13,2026
Conceptual Model of a Quantum Cryostat at Scale N0.1
General OverviewThe image shows a 3D rendering of a conceptual model of a quantum cryostat at scale (inspired by advanced cryogenic cooling systems, such as dilution refrigerators used for quantum computers). The structure features a yellow-gold coloring and is positioned on a light blue planar base. Main Structural ElementsExternal vertical pillars: The architecture is supported by vertical columns connecting the base section to the top platform, providing stability and defining the vertical footprint of the system. Multiple cryogenic stages: At the center of the structure, several levels or concentric disks are visible at various heights. These represent the different progressive cooling stages necessary to thermally isolate sensitive quantum components. Top flange or platform: The model is topped by a flat circular disk, simulating the upper interface plane for the experimental apparatus or control electronics.
General Overview
  • External vertical pillars: The architecture is supported by vertical columns connecting the base section to the top platform, providing stability and defining the vertical footprint of the system.
  • Multiple cryogenic stages: At the center of the structure, several levels or concentric disks are visible at various heights. These represent the different progressive cooling stages necessary to thermally isolate sensitive quantum components.
  • Top flange or platform: The model is topped by a flat circular disk, simulating the upper interface plane for the experimental apparatus or control electronics.
420
26
  • Comments( 1 )
  • Like( 26 )
  • Leave a comment if you liked the project, tell me what you think here in the comments, I’m looking forward to it.
    Oct 26,2026 0 comments
    Reply
