Automation Systems
LoRa dongle
A LoRa transceiver dongle is a compact USB device equipped with a LoRa (Long Range) radio communication module.
LoRa dongle
  • Microchip MPLAB X
    Microchip
It allows a computer or embedded system (such as a Raspberry Pi) to communicate wirelessly over long distances using the LoRaWAN protocol or custom point-to-point LoRa networks.
This dongle contains a USB interface, ATSAMD21 microcontroller with Cortex-M0 core, LoRa transceiver chip (RFM95W), and a SMA connector for an external antenna.
It acts as a bridge between software applications and LoRa-based devices, enabling data transmission and reception with very low power consumption.
Key Features
  • Long-range communication (up to several kilometers)
  • Low power consumption
  • Compact and portable design
  • Plug-and-play USB interface
  • Supports LoRaWAN or custom LoRa protocols
Common Use Cases
  • IoT Gateways
The dongle can be used as a LoRaWAN gateway for small-scale Internet of Things (IoT) deployments. It collects data from LoRa sensors (e.g. temperature, humidity, motion) and forwards it to a server or the cloud.
  • Remote Monitoring
Ideal for agriculture, environmental monitoring, and smart city applications, the dongle enables communication with remote devices in areas where Wi-Fi or cellular coverage is unavailable or unreliable.
  • Development and Prototyping
Engineers and hobbyists can use the dongle for testing and developing LoRa-based solutions without needing a full gateway or base station.
  • Industrial Automation
In factories or warehouses, it helps enable wireless control and monitoring of machines, sensors, or safety systems.
  • Mesh Networking or Point-to-Point Communication
In custom setups, the dongle can participate in direct device-to-device communication, allowing data to hop across nodes or connect end devices without centralized infrastructure.
A LoRa transceiver dongle is an essential tool for developers, engineers, and enthusiasts working with wireless sensor networks and long-range communication technologies.
Main components
  • ATSAMD21E18A-A
  • RFM95W-868S2
  • AP2112K-3.3
LoRa dongle
16.2k
17
  • Like( 17 )
