Marat Zakirov
  • 3 Projects
  • 2 Followers
  • Oct 22,2025
Neptun — Modular Inflatable SUP with Jet Drive
The Neptun is a thoughtfully designed electric inflatable stand-up paddleboard (SUP) that blends performance, safety, and everyday practicality. Built with high-density Drop Stitch fabric, it offers rock-solid rigidity when inflated to 12–15 PSI, yet folds down to backpack size for effortless transport. Every detail — from its vibrant, eye-catching design to its user-focused ergonomics — is crafted to enhance the on-water experience.
Measuring 8 feet in length and 30 inches in width, Neptun provides exceptional stability without sacrificing agility. The 30-inch width strikes the perfect balance: wide enough for confident standing, fishing, or carrying gear, yet narrow enough for responsive turning and easy paddling.
At the heart of Neptun is a self-contained jet drive unit that slots securely into the rear of the hull. This module houses the brushless motor, a removable lithium-ion battery (e.g., 48V 10Ah), and all control electronics — making charging and maintenance as simple as unplugging and lifting out. No tools, no complex wiring — just plug, play, and go.
Steering is intuitive and natural: lean left to turn left, lean right to turn right. The board’s hydrodynamic shape responds smoothly to body weight shifts, eliminating the need for rudders, foot pedals, or handlebars. This creates a seamless, immersive ride that feels like an extension of your own movement.
For safety and peace of mind, Neptun features a full-perimeter grab line (rope) around the entire edge of the board. If you fall in — which happens to everyone — you can easily grab hold and pull yourself back on. This is especially valuable in open water, strong currents, or when riding with children.
At the rear, a large, ergonomic carry handle is integrated into the deck. Made from durable, soft-touch material, it’s designed for comfortable lifting — whether you’re carrying the board down to the shore, loading it into a car, or dragging it across sand. The handle is wide enough for two hands or a shoulder strap, making transport truly effortless.
The deck is fully covered with a textured, non-slip rubberized surface that stays grippy even when wet. Combined with the board’s stable 30-inch width and balanced weight distribution, this ensures confidence whether you’re standing, kneeling, or casting a fishing line.
When the adventure ends, Neptun deflates in minutes. Thanks to its two-section hull design, it folds compactly and fits into a standard backpack — no bulky bag required. Perfect for apartments, small cars, or even air travel.
What’s in the kit?
  • Main inflatable board
  • Snap-in jet drive unit
  • Removable battery pack
  • Compact hand pump
  • Foldable paddle (for emergencies or shallow zones)
  • Carry backpack
Why this matters to the community
Neptun isn’t just about getting from A to B — it’s about reimagining how we interact with water. By combining modularity, intuitive control, and thoughtful safety features, it lowers the barrier to electric water mobility. For makers, it’s a platform for customization — swap batteries, upgrade motors, or add sensors. For everyday users, it’s freedom: silent, zero-emission, and ready to go wherever the water leads. Whether you’re an urban commuter, weekend angler, or coastal explorer, Neptun is built to move with you — quietly, safely, and in style.
5.8k
16
  • Like( 16 )
