Bobricius
  • 1 Projects
  • 1 Followers
  • Apr 27,2026
PICOZX - Handheld ZX Spectrum 128k
PICOZX with ZX Spectrum emulation firmware and 2.8" IPS display and VGA output
MOTHERBOARD ONLY !
Front panel for this updated version is not finished now.
Hardware Specifications
  • Display: 2.8" IPS Screen delivering exceptional clarity with vibrant color reproduction
  • Processor: Powered by the versatile Raspberry Pi PICO microcontroller
  • Connectivity: Micro USB-C interface for data transfer and programming
  • Power: Integrated 18650 lithium battery charging circuit
  • Input: Comfortable 49-button QWERTY keyboard layout
  • Audio: AY sound chip emulation for authentic retro gaming audio
  • Dimensions: Compact 180 × 120 mm form factor
Use Cases
  • Educational Tool: Perfect platform for learning programming concepts
  • ZX Spectrum: Specially optimized for ZX Spectrum emulation, which perfectly matches the 320×240 screen resolution (PICO ZX Spectrum by Fruit-Bat)
SD Card Setup Instructions
To properly configure your device, create the following directory structure on your SD card:
  • /zxspectrum/snapshots - Directory for storing .z80 game snapshot files
  • /zxspectrum/quicksaves - Dedicated folder for your quick-save states
  • /zxspectrum/tapes - Storage location for .tap tape image files
Component List for DIY Assembly
> Important: We do not currently offer component kits or individual parts. Only bare PCB sets or fully assembled units are available.
Essential Components:
Component Quantity Description Notes
Raspberry Pi PICO 2 1 Main microcontroller board RP2350
DTS63K 50 Tactile switches (7mm height, 1N force) Any comparable 1N force switch will provide comfortable typing experience
SD Card Reader 1 Standard microSD card slot Required for retro computer emulation functionality
2.8" IPS Display 1 12-PIN 280×240 ST7789V Purchase options: IPS HP28010-D Option 1 or IPS HP28010-D Option 2
LPT1109DS 1 Piezoelectric element Audio feedback and sound generation
Electronic Components:
Component Quantity Description Function
BSS123 1 Transistor Display backlight control
10R 0603 1 Resistor Display backlight circuit
4.7kΩ 1 Resistor Display backlight bias
JS202011CQN (C&K) or MSS-2235 (NINIGI) 1 Side-mounted switch Power control (device will function without this, but recommended)
  • Firmware
    PICO2ZX-Firmware_151723562369ef03b8297b7.zip
    Download(12)
  • Firmware project page
    https://github.com/fruit-bat/pico-zxspectrum
11.4k
16
  • Like( 16 )
