USBridge Amir Fatkulin
  • 1 Projects
  • 1 Followers
  • Oct 21,2026
USBridge: Remote Access Ecosystem
USBridge Ecosystem is a next-generation ultra-fast remote access ecosystem uniting software and hardware solutions. Hardware Agent (KVM-IP): Delivers ultra-low latency 1080p @ 60 FPS, BIOS access via a text terminal (MSP protocol + AI Vision), ISO mounting, instant BTRFS snapshots, and full pass-through for keyboards, mice, gamepads, and audio. Software Agent: Features a unified open-source hub supporting key protocols: USBridge, Sunshine, Punktfunk, and Vibepollo — allowing you to choose the best option based on built-in benchmarks for your specific needs. Full Tailscale integration ensures secure access from anywhere in the world. DIY KVM: Transform your SBC (Radxa, etc.) or standard Nano KVM into an ultra-fast 1080p @ 60 FPS KVM device with minimal latency. Download the firmware and join the USBridge ecosystem!
USBridge Ecosystem: Next-Gen IP-KVM, Software Agent & Universal Firmware
USBridge Ecosystem is a versatile remote access ecosystem that combines the USBridge-KVM 2.0 hardware, a unified USBridge-Remote software agent, and universal firmware for DIY builds.
Hardware IP-KVM (USBridge-KVM 2.0)
A compact hardware stack engineered for direct infrastructure administration and Layer 0 system debugging, completely bypassing the target device's operating system.
Ultra-Low Latency, Remote Gaming & Input Streaming
Direct integration with the Moonlight protocol enables hardware-level video encoding with sub-perceptible latency: 25–50 ms at 720p and 50–75 ms at 1080p. This entirely eliminates "jelly cursor" input lag, making the device comfortable for both server administration and responsive remote PC gaming. Native gamepad support allows you to play action games remotely with zero perceptible delay.
BIOS-in-Terminal & AI Automation (MSP + AI Vision)
The hardware OCR engine intercepts the raw HDMI signal and converts the graphical BIOS screen into an interactive text stream directly inside an SSH console without relying on cloud services. This allows you to configure BIOS settings even over unstable network connections and copy error logs or serial numbers in a single click. Converting the GUI into structured text enables seamless integration with large language models (such as Claude) via the Model Context Protocol (MCP) for autonomous hardware diagnostics and automated BIOS menu navigation. For automated workflows, an embedded Starlark (Python-syntax) engine evaluates recognized text strings rather than relying on fragile pixel coordinates.
Virtual Media Drive Emulation & Immutable Btrfs Snapshots
Hardware-level drive emulation allows you to mount ISO, VDI, or VMDK files directly from your computer. The target server recognizes them as physical drives and boots seamlessly without requiring file conversions or re-flashing. Data security is backed by an integrated Btrfs filesystem on the KVM layer, which records change differentials and freezes snapshots in read-only mode. Even if an attacker gains full root access on the target server, they physically cannot encrypt or delete backups stored on the KVM.
Hardware Power Management Module
For complete bare-metal control, the unit interfaces directly with the target motherboard's front panel headers. This enables hard resets, power cycles, or cold boots even during severe OS lockups or kernel panics, while providing real-time telemetry for Power LED and HDD activity status.
Software Agent (USBridge-Remote)
A 100% Open-Source cross-platform client for Windows, macOS, Linux, Android, and iOS that unifies your network and KVM nodes into a single management interface. Available on the USBridge-Remote GitHub Repository.
Streaming Protocols & Global Access
The software hub natively supports multiple streaming protocols: USBridge Protocol, Sunshine, Punktfunk, and Vibepollo. Built-in benchmarks allow you to select the best protocol for your specific network conditions directly inside the app. Native Tailscale Mesh VPN integration delivers secure, encrypted remote access from anywhere in the world without complex port-forwarding setup. The agent fully supports modern Wayland and X11 display servers and operates on a self-hosted architecture with zero subscriptions or SaaS fees.
Peripheral Pass-Through
USBridge-Remote delivers low-latency USB/IP forwarding for keyboards, mice, gamepads, audio devices, and graphics tablets, alongside bi-directional clipboard synchronization for text, images, and file transfers between host and client machines.
Universal Firmware (DIY & Nano KVM)
The USBridge ecosystem is completely open to makers, enabling you to build a custom IP-KVM from scratch or upgrade existing hardware.
You can download the universal USBridge firmware and convert your Single Board Computer (such as Radxa Zero 3W or similar SBCs) into a high-performance 1080p@60 FPS KVM. Additionally, the firmware is optimized for standard budget Nano KVM modules, transforming them into ultra-fast KVM units with minimal latency and full integration into the unified USBridge-Remote application.
Comparison with Alternatives
Feature USBridge Ecosystem PiKVM V4 Plus JetKVM Embedded BMC (iDRAC9)
BIOS-in-Terminal (OCR) Yes (Local, Offline) No No No
AI Agents (MCP) & Scripting Yes (MCP / Starlark) No No No
Btrfs Snapshots (Layer 0) Yes (Hardware-level) No No No
Video Protocols Moonlight, USBridge, Sunshine, Punktfunk, Vibepollo WebRTC / H.264 WebRTC (H.264) Web GUI / VNC
Gamepads & Graphics Tablets Yes (Full USB/IP) Limited Limited No
Unified Software Agent USBridge Remote (Cross-platform, Open-Source) Web Browser Web Browser / Desktop Web Browser / Java Applet
DIY / Universal Firmware for Nano KVM Yes (Universal Firmware) No No No
Technical Specifications (USBridge Hardware)
Hardware Architecture: Radxa Zero 3W SoC (Rockchip RK3566, quad-core ARM Cortex-A55), 1–2 GB LPDDR4X RAM with dedicated allocation for virtual media caching, hardware UVC video capture supporting 1080p @ 60 FPS / 720p @ 60 FPS, onboard 240x240 IPS display for POST status monitoring, and active cooling system.
Interfaces & Networking: 2× USB Type-C ports (OTG + Host), 8-pin GPIO header for the ATX Power Management breakout board, MicroSD slot, Micro HDMI local pass-through port, Wi-Fi 6 module, and native Tailscale Mesh VPN support.
Repositories & Resources
  • USBridge Hardware Agent & Universal Firmware
    https://www.usbridge.io/hardware-agent/
  • https://github.com/USBridge-Technologies/USBridge-KVM-2.0
    https://USBridge Hardware
1.0k
33
5
5
  • Comments( 5 )
  • Like( 33 )
  • I’ve overhauled the cooling system, switching it from active to completely passive. No more fan noise or unnecessary moving parts! I replaced the original 0.5 cm tall heatsink with a more substantial 1 cm version, which allows for effective heat dissipation via natural convection. I also optimized the software and processor load to reduce heat generation during peak tasks. As a result, the KVM maintains excellent operating temperatures: under maximum load, the processor stays stable at around 65°C, and at idle, it sits at about 40°C. What do you think?
    Oct 24,2026 0 comments
    Reply
  • This is what it looks like now!
    Reply
  • I’ve just released a video on how I made the USBridge KVM completely silent! ???? Take a look at the evolution of its cooling system: from a noisy 40mm fan to optimized firmware and passive cooling that keeps temperatures around 65°C, even under peak load. https://www.youtube.com/watch?v=A0cC-6mO2vU
    Reply
  • I’ve come up with two versions of a heatsink, and now I’m racking my brain trying to figure out which one will perform better in practice. If the KVM switch is positioned vertically—with the cable connectors facing upward—natural convection should be more effective at venting hot air out through the channels. On the other hand, longitudinal fins provide a somewhat larger total surface area, and I also just happen to prefer how they look.
    Oct 27,2026 0 comments
    Reply
  • That’s really cool, man.
    Oct 30,2026 0 comments
    Reply
