Pabec
  • 61 Projects
  • 9 Followers
  • May 13,2025
SAMD21G18A Sensor Board
Revision 1 of this design works but requires a respin to fix a few issues
Changes I'll make in the Rev2 design
  • add + and - silkscreen to the pads on the lipo battery so you know the polarity
  • add a stronger LDO, the CAT6219-330TDGT3
  • all tracks should be thicker then 6 or 7 mil
  • remove pin 7 on H3, this will mark the polarity for burning the bootloader using the Segger J-link
  • three seperate leds are necessary, right now D13 only lights when connected to USB, D13 one end to +3.3V
  • flex cable on oled is tight, slot or board notch possibly needed
Assembly instructions
GitHub Link: https://github.com/mike-rankin/SAMD21G18A_Sensor_Board/tree/master  This is GitHub account: https://github.com/mike-rankin where you will explore more excellent projects. He is a good DIY maker who designs custom ESP32 IoT projects using Altium Designer, Arduino IDE and Fusion360. Welcome everyone to follow.
1.0k
16
  • Like( 16 )
