Manoranjan Das
  • 10 Projects
  • 9 Followers
  • Aug 07,2025
EasyArduino
The ultimate beginner’s board to learn, build, and master Arduino the easy way.
EasyArduino
🎯 Features
  • ✅ ATmega328P-PU DIP – Arduino Uno compatible
  • 🔌 FTDI 6-pin header for USB upload
  • 🧠 ISP header for bootloader and SPI programming
  • 📶 5x I²C headers with VCC, GND, SDA, SCL
  • 🖲️ All digital (D2–D13) and analog (A0–A5) pins exposed with GND & 5V
  • ⚡ Power input via DC jack (7–30V) and onboard voltage regulators:
    • LM2985-5.0 → 5V
    • AMS1117-3.3 → 3.3V for sensors/ESP
  • 🧪 Test/learning-friendly layout with silkscreen labels
  • 🔘 Onboard RESET button, Power LED, and D13 LED
🧩 Pinout Overview
🔌 Digital Pins (D2–D13)
  • All 3-pin headers: [GND | Dn | 5V]
  • PWM: D3, D5, D6, D9, D10, D11
  • SPI: D10 (SS), D11 (MOSI), D12 (MISO), D13 (SCK)
📈 Analog Pins (A0–A5)
  • Also usable as digital (D14–D19)
📡 I²C (5x Headers)
GND | +3.3V | +5V | SDA | SCL
⚙️ UART & FTDI Header (6-pin)
DTR | TX | RX | +5V | GND | NC
🛠 ISP Header (2×3)
MISO | VCC
SCK  | MOSI
RST  | GND
🛠 Getting Started
🔧 Uploading Code
  1. Connect an FTDI module to the 6-pin FTDI header
  2. In Arduino IDE:
    • Select Board: Arduino Uno
    • Choose correct COM port
    • Upload your sketch!
🔌 Powering the Board
  • Use DC Barrel Jack (7–30V)
  • 5V & 3.3V rails automatically regulated onboard
🔍 I²C Sensor Example
Plug sensor into any I²C header and use code like:
#include <Wire.h>
  Wire.begin(); // I2C init
  Wire.beginTransmission(0x76); // Example address
  Wire.write(0xF4); // Example command
  Wire.endTransmission();
  delay(1000);
🧠 Educational Ideas
  • Solder-it-yourself Arduino kit
  • I²C sensor lab: OLED, BME280, RTC
  • Learn SPI, I2C, UART, PWM
  • Expand with ESP8266 via UART/I²C
🌐 More About Me
📄 License
MIT License – use it freely for education, learning, or hacking!
  • https://github.com/ElectroIoT/EasyArduino
EasyArduino
27.7k
17
  • Like( 17 )
