Dharani Creations
  • 19 Projects
  • 15 Followers
  • Aug 07,2025
Following Robot | Arduino-Based Smart Bot Project
The project involves building a mobile robot—likely using an Arduino microcontroller—that autonomously follows a person by measuring distances with ultrasonic sensors .
  • Arduino UNO R3
  • IR sensor
    X 2
  • Ultrasonic Sensor - HC-SR04
  • SG90 Micro-servo motor
  • 18650 Li-ion Battery & Holder
  • Crowtial- Motor base shield
    X 1 fenxiang
  • DC Motors
    X 4
  • Wheels
    X 4
  • Fritzing
Project Overview
The project involves building a mobile robot—likely using an Arduino microcontroller—that autonomously follows a person by measuring distances with ultrasonic sensors.
Core Components
Based on similar DIY projects, the typical components include:
  • Arduino UNO – The main controller handling sensor data and motor commands.
  • Ultrasonic Sensors (e.g., HC‑SR04) – Often three, placed at the front, left, and right to measure distances to obstacles or a person
  • Motor Driver (e.g., L298N or L293D) – Interfaces between the Arduino and DC motors to control movement .
  • DC Motors with Chassis – Providing locomotion, usually two-wheel setups on a chassis.
  • Power Supply – Batteries such as Li-ion cells to power the motors and Arduino.
  • Wiring and Breadboard – For rapid prototyping and connections.
Wiring and Circuit Design
  • Sensors: Each ultrasonic sensor has Trigger and Echo pins connected to digital I/O pins on the Arduino. Power and ground are common.
  • Motors: DC motors connect via the motor driver to the Arduino. The driver receives direction and speed signals through control pins.
  • Power Management: The motor driver handles higher voltage/current for motors, while Arduino runs from regulated 5 V.
Operational Logic
  1. Reading Distances: The Arduino continuously reads distances from the ultrasonic sensors (front, left, right).
  2. Decision Making: Based on sensor values, the robot decides whether to:
    • Move forward (if the person is ahead),
    • Turn left or right (if the person is off to the side),
    • Stop or back up (if too close) .
  3. Motor Commands: Depending on logic, the Arduino commands the motor driver to move the robot in the appropriate direction.
Example logic from similar projects:
  • If the front sensor distance is below a threshold, move forward.
  • If left distance is less than right, turn left; if right less, turn right.
  • If too close, stop or reverse .
Software & Code Structure
  • Setup (setup()):
    • Initialize sensor pins (Trigger as OUTPUT, Echo as INPUT).
    • Configure motor driver control pins.
    • Start serial communication (for debugging).
  • Loop (loop()):
    • Read sensor distances via functions (e.g., sensorOne(), sensorTwo(), sensorThree()).
    • Print distances (optional).
    • Compare readings to thresholds.
    • Call movement functions: moveForward(), turnLeft(), turnRight(), stop(), moveBackward(), etc.
    • Repeat continuously .
Applications & Extensions
  • Real-World Uses: Shopping cart robots, luggage carriers, assistance robots in public spaces, pet-like companions, surveillance bots, hospital assistance, etc. .
  • Beyond Basic: You could enhance the robot by adding line sensors for obstacle detection, integrating Bluetooth or camera modules, or improving targeting via machine vision.
  • CODE
    https://github.com/DharaniCreations/-Following-Robot-Arduino-Based-Smart-Bot-Project/blob/main/Arduino_Follow_Me_Robot.ino
  • Diagram
    https://github.com/DharaniCreations/-Following-Robot-Arduino-Based-Smart-Bot-Project/blob/main/ARDUINO%20HUMAN%20FOLLOWING%20CAR.jpg
34.0k
15
  • Like( 15 )
