Nontawut Juntaraket
model 3D IoT Smart Farm
"A 3D model of an IoT smart farm that can be controlled via an internet Wi-Fi connection, featuring a solar cell to harness energy from sunlight. This aims to create renewable energy for maximum benefit and cost savings in agriculture, leading to the highest possible yield."
  • SolidWorks
Hello.
What I'm currently working on is an IoT smart farm 3D model. It's a simulation of an IoT smart farm on a large agricultural plot for growing fruits. The system includes a Wi-Fi router to control the ESP32. For the control system, I'm using an ESP32 model with a 38-pin connector for an easy, solder-free connection. There is also a 12V relay model to send control signals to the motor pump for water distribution. 2-inch PVC pipes are used as the main lines, with 1/2-inch PE pipes connected to water the fruit trees.
For the power supply, we are using a solar cell to provide energy to the various components. We use a charger module to receive power from the solar cell, which then goes to a battery. From there, the power is fed to an inverter to convert it from DC to AC, supplying power to the rest of the system.
Thank you.
17.9k
15
  • Comments( 1 )
  • Like( 15 )
