Dharani Creations
  • 19 Projects
  • 15 Followers
  • Aug 05,2025
DIY Electric Bike 50km/h
This project demonstrates how to convert a standard bicycle into a high-performance electric bike (e-bike) capable of reaching speeds up to 50 km/h. It involves integrating an electric motor, battery system, throttle controller, and other essential electronics. The project blends mechanical engineering, electrical systems, and DIY fabrication skills to build a cost-effective and powerful personal transportation solution.
Overview
 Project Goals
  • Convert a regular bicycle into an electric-powered vehicle
  • Achieve a top speed of ~50 km/h
  • Ensure good range (20–40 km depending on battery)
  • Maintain balance between speed, torque, and safety
  • Build a system that supports throttle control and regenerative braking (optional)
 Components Used
Component Description
Brushless DC (BLDC) Hub Motor 500W–1000W rear or front wheel hub motor
Lithium-ion Battery Pack 36V or 48V, typically 10Ah–20Ah
Motor Controller Matched to motor voltage/current, with hall sensor support
Throttle (Thumb or Twist) Sends variable voltage signal to controller
Pedal Assist System (Optional) Enables hybrid manual + motor riding
Display Unit / Speedometer Shows speed, voltage, distance
Controller Box / Mounts Protects electronics from weather/shock
Wiring Harness + Connectors High-current cables, XT60/XT90 or Anderson connectors
Fuses / Circuit Breaker Overcurrent protection
Mechanical Brake System Disc or V-brake with possible motor cutoff
 How It Works
  1. Throttle Input: The rider uses a twist or thumb throttle to signal the motor controller.
  2. Controller Logic: Based on throttle position and battery status, the controller sends power to the motor.
  3. Motor Drive: The BLDC hub motor rotates the wheel, propelling the bike.
  4. Speed Regulation: Speed can be limited by the controller or manually via throttle input.
  5. Battery Supply: A lithium-ion battery supplies DC power to the controller and motor. Proper BMS (Battery Management System) manages charging/discharging safely.
 Build Process (Simplified)
  1. Mount the Hub Motor Wheel:
    • Replace rear or front wheel with the motor-integrated hub.
    • Ensure axle fit and torque arms are installed to prevent rotation.
  2. Install Battery and Controller:
    • Mount battery pack inside the bike frame or on a rear rack.
    • Mount the controller in a waterproof box near the frame.
  3. Wire Everything Up:
    • Connect motor phase wires and hall sensor wires to the controller.
    • Wire throttle, brakes (cutoff), display, and battery connections.
    • Secure and weatherproof all exposed terminals.
  4. Test and Tune:
    • Power on and check motor rotation.
    • Use the display to monitor voltage, current, and error codes.
    • Test ride and adjust throttle response and speed limits.
 Performance Metrics
Parameter Estimate (Varies by Setup)
Top Speed ~45–50 km/h
Range 20–50 km (depending on battery size & terrain)
Motor Power 500W–1000W
Voltage 36V / 48V
Charging Time 4–6 hours
 Advantages
  • Eco-friendly personal transportation
  • Customizable performance (speed, range)
  • No fuel cost, minimal maintenance
  • Great learning project for e-mobility and power systems
 Safety Tips
  • Always wear a helmet
  • Use brake cutoff switches to avoid throttle-while-braking
  • Mount battery securely and away from impact zones
  • Include fuses or BMS for battery protection
  • Ensure legal compliance with local e-bike laws (speed/power limits)
???? Optional Upgrades
  • Regenerative Braking
  • Cruise Control
  • Bluetooth App Integration for stats monitoring
  • Solar Charging
  • Smart BMS with individual cell monitoring
  • LED lights and horn integration
6.5k
15
  • Like( 15 )
