Monitoring and Controling Tools by humidity and temperature
"A smart IoT-based system that monitors and controls temperature and humidity in real-time, combining precision, automation, and remote accessibility in one compact device."
  • SIM900A Module SIM900 GSM GPRS SHIELD Serial SIM 900A n Antena a
  • Ac Light Dimmer Robotdyn Module 2 Dual Channel 220V 110V Logic 5
  • FOTEK SSR-25DA-H MADE IN TAIWAN SSR 25DAH Solid State Relay Fote
  • TTL RS232 TO RS485
  • Saklar Power Rocker Switch On Off Saklar Roker Mini KCD-1 2pin 3
  • Box Project X5 Hitam Plastik 145x95x50 mm Case Enclosure for Ard
  • Header FCP 1X40 MALE 2.54MM
  • Temperature and Humidity Transmitter Modbus SHT20 Sensor
  • Expansion Shield Terminal Adapter IO Shield For Arduino Nano V3
  • ARDUINO NANO V3 ATMEGA328P CH340G 5V BOARD TYPE-C
  • PCB POLOS DOUBLE LAYER FR4 FIBER 10X15CM
  • LED Diffused Round
Goods
  • RemoteXY mobile app
    Evgeny Shemanuev
  • Arduino IDE for programming, Blynk IoT app for real-time monitor
  • Particle Build Web IDE
This project is a smart temperature and humidity monitoring system using an Arduino Nano, DHT22 sensor, and SIM900A GSM module, designed to automatically control a heater and fan through solid-state relays (SSR) based on real-time environmental data. The system displays current readings on a 16x2 I2C LCD and allows remote access via SMS commands, making it ideal for applications such as greenhouses, incubators, or temperature-sensitive storage rooms. With simple components, reliable GSM connectivity, and an efficient control mechanism, this project offers a practical and low-cost solution for remote climate control without relying on Wi-Fi networks.
  • Program Source Simple code
    sketch_Code_MNT_1066188544687eeb8c07677.zip
    Download(4)
  • wiring diagram
    Download(4)
  • Technical drawing
28.3k
19
2
  • Comments( 2 )
  • Like( 19 )
  • nice project
    Jul 24,2025 0 comments
    Reply
  • really nice!
    Sep 10,2025 0 comments
    Reply
