Luc Paquin
  • 77 Projects
  • 19 Followers
  • Mar 13,2026
Project #15: Environment - AHT20 Temperature and Humidity -
Project #15: Environment - AHT20 Temperature and Humidity - Mk35
  • DFRobot FireBeetle 2 ESP32-E
    DFRobot
  • Fermion: 3.5” 480x320 TFT LCD Capacitive
    DFRobot
  • GDL Line 10 CM
    DFRobot
  • Gravity: AHT20 Temperature and Humidity Sensor
    DFRobot
  • Flame Sensor
  • Crowtail - LED Green
    Elecrow
    X 1 fenxiang
  • Gravity: IO Shield for FireBeetle 2
    DFRobot
  • Terminal Block Board for FireBeetle 2 ESP32-E IoT
    DFRobot
  • Lithium Ion Battery - 1000mAh
    DFRobot
  • USB 3.0 to Type-C Cable
    DFRobot
  • Arduino IDE (programming)
Web
https://www.donluc.com/?p=4750
Facebook
https://www.facebook.com/share/v/18EcnNCjte/
YouTube
https://youtu.be/P_L0GK5nrys
DFRobot
https://learn.dfrobot.com/makelog-315141.html
Hackster
https://www.hackster.io/luc-paquin/project-15-environment-aht20-temperature-and-humidity-760f0b
#DonLucElectronics #DonLuc #FlameSensor #AHT20 #FireBeetle2ESP32E #ESP32 #Display #IoT #Project #Fritzing #Programming #Electronics #Microcontrollers #Consultant
The AHT20 is a high-precision but low-cost temperature and humidity sensor, which is equipped with an improved MEMS semiconductor capacitive humidity sensor element. It features standard I2C interface and a wide voltage supply of 2 Volt - 5 Volt, and with the simple peripheral circuit, it performs stably even in harsh environments in the measuring range of -40C ~ +85C. This sensor can be widely used for measuring the environmental temperature and humidity of home electronic equipment, the temperature and humidity of automobiles, and so on.
DL2602Mk07
1 x DFRobot FireBeetle 2 ESP32-E
1 x Fermion: 3.5” 480x320 TFT LCD Capacitive
1 x GDL Line 10 CM
1 x Gravity: AHT20 Temperature and Humidity Sensor
1 x Flame Sensor
1 x Crowtail - LED Green
1 x Gravity: IO Shield for FireBeetle 2
1 x Terminal Block Board for FireBeetle 2 ESP32-E IoT
1 x USB 3.0 to Type-C Cable
DL2602Mk07p
DL2602Mk07p.ino
getDisplay.ino
getEEPROM.ino
getFlame.ino
getHT.ino
setup.ino
-Programming Language
-IoT
-Robotics
-Automation
-Unmanned Vehicles Terrestrial, Marine and UAV
-Machine Learning
-Artificial Intelligence (AI)
-RTOS
-Consulting
-Etc...
Follow Us
https://www.donluc.com/luc/LucPaquinCVEng2026Mk01.pdf
Web: https://www.donluc.com/
Don Luc
  • DL2602Mk07p
    DL2602Mk07p_209952210169b2f0ec512b3.zip
    Download(0)
727
15
  • Like( 15 )
