Luc Paquin
  • 77 Projects
  • 19 Followers
  • Apr 09,2026
Project #15: Environment - SD Card Module - Mk37
Web
https://www.donluc.com/?p=4805
Facebook
https://www.facebook.com/share/v/1Hcc2YroPP/
YouTube
https://youtu.be/vzM0kWzgRGg
DFRobot
https://learn.dfrobot.com/makelog-315206.html
Hackster
https://www.hackster.io/luc-paquin/project-15-environment-sd-card-module-mk37-214c45
#DonLucElectronics #DonLuc #SD #Buzzer #FlameSensor #AHT20 #FireBeetle2ESP32E #ESP32 #Display #IoT #Project #Fritzing #Programming #Electronics #Microcontrollers #Consultant
Fermion: SD Card Module
This DFRobot SD card shield is a Break out board for standard SD card. It allows you to add mass storage and data logging to your project. Specification Compatible with standard SD cards and Micro SD (TF) cards. Can be directly plugged into Arduino shields. Can also be used with other microcontrollers (via SPI communication).
DL2603Mk02
1 x DFRobot FireBeetle 2 ESP32-E
1 x Fermion: 3.5” 480x320 TFT LCD Capacitive
1 x GDL Line 10 CM
1 x Fermion: MicroSD Card Module
 1 x MicroSD 2 GB
1 x Crowtail - Buzzer 2.0
1 x Gravity: AHT20 Temperature and Humidity Sensor
1 x Flame Sensor
1 x Crowtail - LED Green
1 x Gravity: IO Shield for FireBeetle 2
1 x Terminal Block Board for FireBeetle 2 ESP32-E IoT
1 x USB 3.0 to Type-C Cable
DL2603Mk02p
DL2603Mk02p.ino
getDisplay.ino
getEEPROM.ino
getFlame.ino
getHT.ino
getSD.ino
setup.ino
-Programming Language
-IoT
-Robotics
-Automation
-Unmanned Vehicles Terrestrial, Marine and UAV
-Machine Learning
-Artificial Intelligence (AI)
-RTOS
-Consulting
-Etc...
Follow Us
https://www.donluc.com/luc/LucPaquinCVEng2026Mk01.pdf
Web: https://www.donluc.com/
Don Luc
3.9k
14
  • Like( 14 )
