Luc Paquin
  • 77 Projects
  • 19 Followers
  • Nov 13,2025
Project #28 – Sensors – Digital Magnetic Sensor – Mk16
  • DFRobot FireBeetle 2 ESP32-E
    DFRobot
  • Fermion: 2.0" 320x240 IPS TFT LCD
    DFRobot
  • GDL Line 10 CM
    DFRobot
  • Gravity: IO Shield for FireBeetle 2
    DFRobot
  • Gravity: Digital Magnetic Sensor
    DFRobot
  • Gravity: Digital RGB LED Module
    DFRobot
  • Lithium Ion Battery - 1000mAh
    DFRobot
  • Switch
  • USB 3.0 to Type-C Cable
    DFRobot
Web
https://www.donluc.com/?p=4594
Facebook
https://www.facebook.com/reel/1744858636214306
YouTube
https://youtu.be/k0pGOtccneI
DFRobot
https://learn.dfrobot.com/makelog-315058.html
#DonLucElectronics #DonLuc #Magnetic #FireBeetle2ESP32E #ESP32 #DFRobot #Display #IoT #Project #Fritzing #Programming #Electronics #Microcontrollers #Consultant
Detect nearby magnetic objects with this digital magnetic sensor, offering a 3.3 Volt - 5 Volt range, easy interfaces, high quality connector, and compact size.
Gravity: Digital RGB LED Module is a cascadable single RGB LED module compatible with RGB LED strip. Compared to the traditional RGB LED module, where three control signal pins are required for a single LED, this module only needs one signal pin for all LEDs in cascade. Thanks to such individual module design, RGB LED strip built by such independent modules can realize extremely low power consumption
DL2510Mk05
1 x DFRobot FireBeetle 2 ESP32-E
1 x Fermion: 2.0" 320x240 IPS TFT LCD
1 x GDL Line 10 CM
1 x Gravity: IO Shield for FireBeetle 2
1 x Gravity: Digital Magnetic Sensor
1 x Gravity: Digital RGB LED Module
1 x Switch
1 x USB 3.0 to Type-C Cable
DL2510Mk05p
DL2510Mk05p.ino
getDisplay.ino
getEEPROM.ino
getMagnetic.ino
setup.ino
-Programming Language
-IoT
-Robotics
-Automation
-Unmanned Vehicles Terrestrial,  Marine and UAV
-Machine Learning
-Artificial Intelligence (AI)
-RTOS
-Consulting
-Etc...
Follow Us
https://www.donluc.com/luc/
Web: https://www.donluc.com/
Don Luc
594
15
  • Like( 15 )
