Luc Paquin
  • 77 Projects
  • 19 Followers
  • Dec 25,2025
Project #28 – Sensors – MAX30102 PPG Sensor – Mk21
  • DFRobot FireBeetle 2 ESP32-E
    DFRobot
  • Fermion: 3.5” 480x320 TFT LCD Capacitive
    DFRobot
  • GDL Line 10 CM
    DFRobot
  • Gravity: IO Shield for FireBeetle 2
    DFRobot
  • Terminal Block Board for FireBeetle 2 ESP32-E IoT
    DFRobot
  • Gravity: MAX30102 PPG Heart Rate and Oximeter Sensor
    DFRobot
  • Lithium Ion Battery - 1000mAh
    DFRobot
  • USB 3.0 to Type-C Cable
    DFRobot
  • Arduino IDE (programming)
Web
https://www.donluc.com/?p=4641
Facebook
https://www.facebook.com/share/v/1D78aX3Rk4/
YouTube
https://youtu.be/d-Jo6_4NsuQ
DFRobot
https://learn.dfrobot.com/makelog-315085.html
Hackster
https://www.hackster.io/luc-paquin/project-28-sensors-max30102-ppg-sensor-mk21-31dab1
#DonLucElectronics #DonLuc #MAX30102PPG  #FireBeetle2ESP32E #ESP32 #DFRobot #Display #IoT #Project #Fritzing #Programming #Electronics #Microcontrollers #Consultant
Photoplethysmography
A PPG sensor is a non-invasive optical device that uses light (usually LEDs) and a photodetector to measure changes in blood volume in tissues, commonly used in wearables for monitoring heart rate, oxygen saturation (SpO2), and respiration by detecting fluctuations in light absorption or reflection as blood pumps through vessels. These sensors are cost-effective and popular in smartwatches and fitness trackers, working by shining light into the skin and analyzing how much light returns, which varies with each heartbeat.
DFRobot Gravity: MAX30102 heart rate and blood oxygen sensor module integrates the Maxim MAX30102 chip and an MCU with heart rate and blood oxygen algorithm. The MAX30102 uses PPG to measure data, which will be converted into heart rate and oximetry values when processed by the MCU, then output through I2C or UART, making the sensor easy to use and greatly reducing resource occupation of the main controller. The pressure may change when the finger is directly pressed down the sensor, which will affect the data output. So please try to fix the sensor on your finger. Wear the sensor on your finger and there is no difference in the direction of wearing.
DL2512Mk03
1 x DFRobot FireBeetle 2 ESP32-E
1 x Fermion: 3.5” 480x320 TFT LCD Capacitive
1 x GDL Line 10 CM
1 x Gravity: IO Shield for FireBeetle 2
1 x Terminal Block Board for FireBeetle 2 ESP32-E IoT
1 x Gravity: MAX30102 PPG Heart Rate and Oximeter Sensor
1 x USB 3.0 to Type-C Cable
DL2512Mk03p
DL2512Mk03p.ino
getDisplay.ino
getEEPROM.ino
getPPG.ino
setup.ino
-Programming Language
-IoT
-Robotics
-Automation
-Unmanned Vehicles Terrestrial,  Marine and UAV
-Machine Learning
-Artificial Intelligence (AI)
-RTOS
-Consulting
-Etc...
Follow Us
https://www.donluc.com/luc/
Web: https://www.donluc.com/
Don Luc
842
15
  • Like( 15 )
