Luc Paquin
  • 77 Projects
  • 19 Followers
  • May 01,2025
Project #30 - UNIHIKER - Ambient Light - Mk11
Project #30 - UNIHIKER - Ambient Light - Mk11 #DonLucElectronics #DonLuc #Light #UNIHIKER #Display #IoT #Project #DFRobot #Fritzing #Programming #Electronics #Microcontrollers #Consultant
https://www.donluc.com/?p=4407
https://www.facebook.com/share/p/1BX9c3qX69/
https://youtu.be/rmtXrJNkVz4
https://www.facebook.com/share/p/1FAmknDpJN/
https://learn.dfrobot.com/makelog-314970.html
LITE-ON Technology - Ambient Light Sensor
The LTR-303ALS-01 is a low voltage I2C digital light sensor [ALS] in a low cost miniature chipled lead-free surface mount package. This sensor converts light intensity to a digital output signal capable of direct I2C interface. It provides a linear response over a wide dynamic range from 0.01 lux to 64k lux and is well suited to applications under high ambient brightness.
Gravity: Analog Ambient Light Sensor
This Gravity: Analog ambient light sensor can assist you in detecting light density and provide an analog voltage signal to the controller as feedback. Additionally, you have the ability to trigger other components within your project by setting voltage thresholds.
DL2504Mk06
1 x UNIHIKER K10
1 x Gravity: Analog Ambient Light Sensor
1 x Switch
1 x USB 3.1 Cable A to C
DL2504Mk06p
DL2504Mk06p.mp
Electronics, IoT, Teacher, Instructor, R&D and Consulting
-Programming Language
-IoT
-Robotics
-Automation
-Machine Learning
-Artificial Intelligence (AI)
-RTOS
-Consulting
-Etc...
Follow Us
https://www.donluc.com/luc/
Web: https://www.donluc.com/
Don Luc
1.6k
17
  • Like( 17 )
