Kristóf Frank
Smart Plant Guardian
Smart Plant Guardian is an IoT-enabled, energy-efficient plant care system that automatically monitors and maintains optimal growing conditions while providing real-time data to users through a mobile app.
  • DHT22 Temperature/Humidity Sensor
  • Micro Submersible Water Pump (5V DC, ~100L/H)
  • Soil-Based Energy Harvester Module
  • 18650 Li-ion Battery & Holder
  • 5V 1W Solar Panel (with JST connector)
  • RGB LED Common Anode
  • Water Level Sensor (Floatless Type)
  • MIT App Inventor/Blynk Services
  • Core Electronics
  • IoT/Cloud Services
  • Blynk
  • MIT App Inventor 2
    MIT App Inventor
The Smart Plant Guardian is an IoT-enabled, self-sustaining plant care system that automatically monitors and maintains optimal growing conditions for your plants. It combines sensors, automation, and solar power to:
✅ Monitor soil moisture, temperature, humidity, and light levels.
✅ Automatically water plants when needed.
✅ Alert you via a mobile app if something’s wrong.
✅ Run on solar + battery power for eco-friendly operation.
Perfect for home gardeners, urban farmers, and electronics enthusiasts who want a hands-off approach to plant care!
System Overview
  1. Sensors measure soil moisture, temperature, humidity, and light.
  2. Crowduino (Arduino-compatible) processes data and decides when to water.
  3. Water pump activates when soil is too dry.
  4. WiFi (ESP8266) sends data to your phone via Blynk/MIT App Inventor.
  5. Solar panel + battery keep it running without outlets.
Components Needed
Component Where to Buy
Crowduino (Arduino) Elecrow
Soil Moisture Sensor Elecrow/Amazon
DHT22 Sensor Amazon/AliExpress
5V Water Pump AliExpress/SparkFun
ESP8266 (WiFi) Elecrow/Amazon
0.96" OLED Display Elecrow
Solar Panel (5V 1W) Adafruit/eBay
Wiring Guide
Component Crowduino Pin
Soil Moisture Sensor A0
DHT22 Sensor D2
Light Sensor A1
Water Pump D5 (via Relay)
ESP8266 (WiFi) RX/TX (UART)
Install Required Libraries
#include <DHT.h>
#include <ESP8266WiFi.h>
#include <Adafruit_SSD1306.h>
2. Main Logic (Simplified)
arduino
Copy
  int moisture = analogRead(A0);
  if (moisture < 30) {  // If soil is dry
    digitalWrite(PUMP_PIN, HIGH);  // Turn on pump
    delay(2000);  // Water for 2 seconds
    digitalWrite(PUMP_PIN, LOW);
Option 1: Blynk (Easiest)
  1. Download Blynk App (iOS/Android).
  2. Create a project with:
    • Live Soil Moisture Gauge
    • Button for Manual Watering
    • Alert Notifications
Option 2: MIT App Inventor (Customizable)
  • Drag-and-drop UI with HTTP/MQTT for sensor data.
🔋 Step 4: Power & Enclosure
  1. Solar Panel → TP4056 Charger → 18650 Battery
  2. 3D-Printed Case (Download STL Files)
    • Waterproof electronics compartment.
    • Modular sensor mounts.
Demonstration Video
▶️ Watch How It Works! (Link to YouTube demo)
💡 Why This Project Matters
  • Saves Plants from over/under-watering.
  • Teaches IoT, Sensors, and Automation in a practical way.
  • Open-Source & Hackable – add cameras, AI, or voice control!
⚠️ Common Pitfalls & Fixes
Issue Solution
Pump not turning on Check relay wiring + power supply.
WiFi disconnects Use stable 3.3V for ESP8266.
Wrong moisture readings Calibrate sensor in dry/wet soil.
  • Technical drawing
  • Technical drawing
19.9k
12
  • Like( 12 )
